SMath up to 0.96.4909 > password: testSMath 0.97.5301 or later > link a variable in the placeholder and left-click on the region to export the variable to the clipboard (clipboard's content can be pasted in spreadsheets or text editors - can't be used as variable in SMath) Also, you can paste spreadsheets data directly in the region placeholder. PLEASE REPORT HERE ANY ISSUEBest regards, Davide Edited by user 14 July 2014 10:56:46(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
3 users thanked Davide Carpi for this useful post.
on 27/09/2013(UTC), on 27/09/2013(UTC), on 05/09/2022(UTC)
Was thanked: 3 time(s) in 3 post(s)
looking great websurfer. Looks like you're all about the extensions now.
Thanks Davide Try to reproduce this one A:=something(2)where something() is not defined. This will crash Smath for me. Regards, Radovan Edited by user 27 September 2013 19:15:00(UTC)
| Reason: Not specified omorr attached the following image(s): |
Thank you both, I'll check the issue Btw as I've written in another topic I hope that a "copy special" and a "paste special" will be implemented natively in smath, from context menu (and maybe from shortcuts, like ctrl+ shift +c to make the "external copy" )". Since that day I hope this plugin will help. Edited by user 27 September 2013 19:31:54(UTC)
| Reason: edit |
Originally Posted by: omorr Thanks Davide Try to reproduce this one A:=something(2)where something() is not defined. This will crash Smath for me. Regards, Radovan fixed & updated [edit] working to add both import and export featuresEdited by user 29 September 2013 00:21:25(UTC)
UPDATED
- added "import data" |
Joined: 26/05/2013(UTC) Posts: 21 Was thanked: 1 time(s) in 1 post(s)
After installing the ClipboardRagion pluging Smath displays the error as follows. I have neither the possibility of deleting nor re-installing. Edited by user 10 March 2014 10:33:01(UTC)
| Reason: Not specified experimentator attached the following image(s): |
Learning by doing |
Originally Posted by: experimentator After installing the ClipboardRagion pluging Smath displays the error as follows. I have neither the possibility of deleting nor re-installing. Just search for the dll and remove the associated folder structure, typically "some cryptic name/some version number". Currently that is the only way to remove plugins. It may help to locate the settings directory using the function SettingsDirectory(). There you find folders extensions/plugins, where the above-mentioned plugin directories reside. |
Danke Martin, it works, but I cannot install the extension again, occurs the same problem. |
Learning by doing |
Originally Posted by: experimentator Danke Martin, it works, but I cannot install the extension again, occurs the same problem. That's because the Clipboard Region plugin has not yet been updated to SMath Studio 0.97 (there were API changes). Also there might be problems in actually doing the update (Davide reported problems with clipboard handling). |
Originally Posted by: mkraska That's because the Clipboard Region plugin has not yet been updated to SMath Studio 0.97 (there were API changes). Also there might be problems in actually doing the update (Davide reported problems with clipboard handling). Exactly, as for now this plugin works only with SMath up to 0.96.4909; a new plugin will be relased when Andrey will fix the issues in the clipboard interface. Best regards, Davide Edited by user 10 March 2014 14:00:30(UTC)
Originally Posted by: w3b5urf3r_reloaded Exactly, as for now this plugin works only with SMath up to 0.96.4909; a new plugin will be relased when Andrey will fix the issues in the clipboard interface. Don't know exactly what is the default behavior for plugins uploaded before the introduction of the target version in the Extensions Menager, this plugin should be not visible; anyway it is just a transitory issue... Edited by user 10 May 2014 17:09:26(UTC)
UPDATED SMath 0.97.5301- Updated to fit recent API changes; - fixes; - New features: paste inside placeholder; Be sure to have the "Exclude beta-versions" uncheckedEdited by user 14 July 2014 11:01:53(UTC)
on 14/07/2014(UTC), on 14/07/2014(UTC)
Hi all, First of all, sorry for reopening such an old topic but.... hasn't anybody had an issue then trying to import to smath negative values from excel? Maybe it's related with revision changes in both smath and excel, but when I have negative values I get them imported as text, between quotes "-0.534" i.e
any idea about how to solve that?
Thanks,
I'll check it, thank you for reporting the issue. |
Groups ready for retrieval: Registered
Originally Posted by: Reiltar "-0.534" i.e any idea about how to solve that? In the mean time it will doctored otherwise.
Originally Posted by: Davide Carpi I'll check it, thank you for reporting the issue. Hi Davide. Related, though not exactly a plugin question. But since you are going to see the question of the sign in strings, do you know how to specify a negative exponent inside SMath, as in the following example? Thanks in advance. Alvaro.
on 29/08/2022(UTC), on 30/08/2022(UTC)
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
Alvaro an alternative way is while a better solution is given.
2 users thanked churichuro for this useful post.
on 30/08/2022(UTC), on 30/08/2022(UTC)
Hi Churichurro. Thanks, it is a very good workaround, it works, substituting str2num(strrep(STR,"E-","*10^-" ) )
Best regards. Alvaro.
Originally Posted by: Jean Giraud Originally Posted by: Reiltar "-0.534" i.e any idea about how to solve that? In the mean time it will doctored otherwise. Thanks for this temporary solution.
