Offline mikekaganski
#1 Posted : 19 May 2016 13:56:15(UTC)
mikekaganski
Currently, the custom units of result placeholder has scope of whole expression. So, e.g. trying to select result (15°C) in following line:
288.15*'K=15@'°C
results in whole expression being selected, not only part after "=".
If possible, please enable that selection, to make it easy to copy only result.
Best regards,
Mike Kaganski
#2 Posted : 19 May 2016 15:24:02(UTC)
Originally Posted by: mikekaganski Go to Quoted Post
copy only result.
Maybe like this Mike.
Offline Andrey Ivashov
#3 Posted : 19 May 2016 18:50:48(UTC)
Rank: Administration
Jean, I think Mike requests something like this:
Will check if it is possible to implement Wink
on 20/05/2016(UTC)
Offline CBG
#4 Posted : 19 May 2016 19:31:19(UTC)
CBG
Or something like this..
thanks 1 user thanked CBG for this useful post.
on 20/05/2016(UTC)
#5 Posted : 20 May 2016 01:02:30(UTC)
on 20/05/2016(UTC),  on 20/05/2016(UTC)
#6 Posted : 21 May 2016 14:32:41(UTC)
mikekaganski
Great!
In the same time, it made it more convenient to remove result with custom units, if I decided that I don't want to see the result at all with the expression.
Before, I needed to remove custom unit explicitly, now I just put cursor to the result and hit Backspace several times.
Thanks again!
Best regards,
Mike Kaganski
