This work sheet evaporated itself since unknown date. My most recent backup is dead too. Maybe collab can rescue and make an image of the most essential. In any case: thanks, Jean Contour Advisor [Mathematica].sm (1,257kb) downloaded 15 time(s).
Originally Posted by: Jean Giraud This work sheet evaporated itself since unknown date. My most recent backup is dead too. Maybe collab can rescue and make an image of the most essential. In any case: thanks, Jean Contour Advisor [Mathematica].sm (1,257kb) downloaded 15 time(s). I Just opened it (successfully) and saved it again: Contour%20Advisor%20[Mathematica].smz (55kb) downloaded 19 time(s).Edited by moderator 27 May 2016 14:12:32(UTC)
| Reason: marked as solved (this was a bug fixed in one of the 0.98 versions)
Thanks Alex, most appreciated: Jean
