SMath Studio Forum
Bugs & Problems
[X-Y Plot plugin] cannot plot the function "x" (undefined function error)
A very unpleasant bug that one may prefer his audience does not capture. Forum X_Y BUG.sm (14kb) downloaded 14 time(s).Edited by moderator 26 June 2016 13:48:36(UTC)
| Reason: title updated - marked as bug
I don't understand what it means. Could you explain more transparent. |
Hello Uni, Just like this, a nuance to be aware of Jean Forum X_Y BUG.sm (12kb) downloaded 12 time(s).
... in short: X_Y does NOT plot 'x' it plots ONLY numeric, either: '1*x' or 'x+0' just something weird [Maxima weak code].
Jean, On your graph, is the red diagonal line a "fly-back"? There was a "fix" for that in Mathcad that involved how to set up your graph. If it is, let me know and I will look for my notes on how to fix it.
Hello Jean, Originally Posted by: Jean Giraud it is the same bug (topics merged) Edited by user 17 January 2017 12:08:58(UTC)
Thanks Davide:
Same bug that was detected 5346. Was doctored, but weird ! Maybe Smath Designers you should consider publishing a list of known bugs. Mathematica 4.0 did it, they had some explanation about unsolved bugs.
Originally Posted by: Jean Giraud Maybe Smath Designers you should consider publishing a list of known bugs. Mathematica 4.0 did it, they had some explanation about unsolved bugs.
How about using the bug tracking system (Bugs button above)? If you post your bug reports there, it is much easier for the developers to keep track of them. |
SMath Studio Forum
Bugs & Problems
