Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Many thanks to Viacheslav. It works fine now. |
Quote:Please, could you make a list with the external names of parameters. I think that we need a special function to change the settings. Something like this: xyplot( index, "parameter's name", value) = .... I will try to add this feature. |
on 07/10/2015(UTC), on 07/10/2015(UTC)
Ah !, Martin: you missed plotting your "datum" 0.5^2 Just made that work sheet quick. True, X_Y plot is big cannon for the 1rst contour and Waterloo for the 2nd contour. Some tips added, not refined [just from foundry]. Cheers, Jean
Human eye example (you lost β). |
Originally Posted by: uni Human eye example (you lost β . ____________________ Thanks Uni, Beta got lost in the transit ... Beta is 2 in my work sheet Jean
Something crooked happend in this forum. A minute ago there was a big display about "plotG", now gone. From recollection it's about plotting points. "plotG" is obsolete: to cumbersome, too slow. "plotG" is OK for few points Jean Utilities Plot Points.sm (19kb) downloaded 97 time(s).
Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: mkraska Originally Posted by: uni Quote:Open issues: - handling of undefined values Updated. Try again. Thanks for the update. Plotting ln(x) now works. Still I keep annoying. Division by zero causes trouble. I frequently use this as a handy trick to limit curves to certain ranges. i tried and not sure how how to plot ln(x) as previously shown. is there a way to do it still by just typing in ln(x)?
Division by zero causes trouble. I tried and not sure how how to plot ln(x) as previously shown. Is there a way to do it still by just typing in ln(x)
____________________________________________
There are several things in there to know.
Smath is granular, very granular. It means that between two numerical values, it won't distinguish which one is true because Smath is a 32 bits system. It is not a full extended 64 floating point. Smath will calculate ln(10^-99) and will issue error message "ln(0) is not defined" for ln(10^-100) Mathcad/Mathsoft calculates ln(10^-307) no sweat. Mathcad/Mathsoft is much less granular [extended floating point 64] Convention is that ln(0) is defined complex to enable issuing an error message for most unguarded systems.
X_Y plot is superb for plotting most difficult contour f(x,y) but for other math stuff, X_Y plot is [just read me: piece of crap].
Plot ln(x+epsilon) .... espilon:= 10^-99 As well plot ln(|x|) .... |x| absolute.
Division by zero is just one or more than one coinciding occurence(s). You will have that in any system. Just make the project not to divide by 0
Joined: 27/05/2016(UTC) Posts: 76 Location: Little Rock, Arkansas Was thanked: 9 time(s) in 7 post(s)
First, let me say a big "thank you" for this X-Y Plot. It has been very helpful for me. I found your example file with worksheet controls for some of the parameters like X & Y limits. That was exactly what I needed as I wanted to scale a graph to have extents 10% greater than the worksheet values being graphed. But is there a list of all of the parameters that can be controlled through the worksheet? Since you are using XYPlot as the variable name and the parameter as the subscript, what would you use for parameters like the names of each data series? Or are there even worksheet controls set up yet for those parameters? I do keep having an issue with the names of the 4 data series in my graph disappearing, and the legend description then being blank, so I think tying those to a worksheet definition would be beneficial. Thank you again for all the hard work!
Jason |
Hello, Jason: The Maxima X_Y plot and the Smath Quickplot [@] are two different animals. On simple projects, either one will do. Ofen you need both for same project. The X_Y plot is gorgeous to plot implicit f(x,y) as it plots the 0 level contour, the 0 level contour interpreted as f(x,y)=0. I just noticed that it may be wrong. The X_Y plot in work sheet "Wolfram looping" is wrong. I have two proofs of this assertion: Mathcad 11 & Smath Quickplot. On the other hand, the X_Y plot for "Doublet" is quite correct. The X_Y "Wolfram Looping" seems to upset X_Y because of so many complex sub-plot components [my guess], X_Y gets lost or interprets unknown. Plotting is quite a skill to acquire, no matter the tool. Jean 2D Plot ln(x).sm (9kb) downloaded 82 time(s). Contour Advisor [Wolfram Looping].sm (121kb) downloaded 67 time(s). Both work sheets are: Smath 5346 OFFicial release.
4.sm (48kb) downloaded 78 time(s).The parameterization of implicit functions by Draghilev method1."Quiz function", 2."Human eye" Schedule parameterized function coincides with the graph of X-Y Plot Region (dot). Edited by user 21 October 2018 20:23:24(UTC)
2 users thanked Ber7 for this useful post.
on 21/09/2016(UTC), on 21/09/2016(UTC)
Was thanked: 8 time(s) in 4 post(s)
Hello all, I tried to follow this discussion, but I'm not convinced I've found the answer to this: what syntax is required to change the value of Chart2DLib.LineStyle of an X-Y Plot from the Math region? I managed to change the XYPlot.XLimMin etc. follwing the example in the reference book, but I could do with my line styles not being reset everytime I get some duff values to the plot region. Also: I'd like to place some labels and symbol in my plot to make it look more like a CAD drawing. Is there a way to draw them as is possible with the built-in 2D plot region? All help is welcome. Regards, Marco Edited by user 01 August 2017 18:20:22(UTC)
1. You can place legend in any of the 4 corners. 2. On the main menu: click <list> to access the plot specifications. 3. plot ln(x) is OK because computable by default. 4. plot x^(0.5-1)*exp(-x) will freeze/crash the X_Y page, no rescue for that page. Close computer might rescue the other pages that were working before the crash.
Search this forum containing "Isometric" [this spring]
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 509 time(s) in 339 post(s)
Tried with Smath 0.98.6604. Observed the bug both at W10-x64 and W7-x86. Don't know if previous versions behave the same. While the Plot can comprehend the evaluation inside sys(), X-Y Plot needs an additional line() to be used. However, when two matrix is augmented inside the graphic first matrix is being used twice. Duplication doesn't seems to happen with the stack. Regards X-Y Plot.sm (19kb) downloaded 64 time(s).
Yeah Jean, I know it can be plotted that way or another. But I have my own reasons to do the augmentation inside the plot and recursive "M:=(augment(N;M)" method. While I can do it with built-in plot, I can't do it with X-Y Plot Plugin. And if you do it like "MM:=(augment(N;M)" it can be plot correctly because augment command is generating correct matrix. The problem is here is not the plotting, augment is giving wrong result. This is why I considered this as a bug. Regards Edited by user 02 February 2018 11:02:23(UTC)
Which version of smath studio should I use? I just downloaded 0.99 and it didn't work out. thanks
