Offline mdominiak
#1 Posted : 18 February 2017 10:03:25(UTC)
mdominiak
Rank: Member
Poland
Hi there,
is it possible to get exact point of functions intersection in Smath somehow? I have simply linear and constant function.
BR,
Marcin
Offline PompelmoTell
#2 Posted : 18 February 2017 12:00:22(UTC)
PompelmoTell
There are more opportunities: without the use of plugins, for example, you can use the function or the method of inversion of the matrix.
thanks 1 user thanked PompelmoTell for this useful post.
on 18/02/2017(UTC)
Offline mdominiak
#3 Posted : 18 February 2017 12:45:09(UTC)
mdominiak
Rank: Member
Poland
Thanks!
What with quadratic or higher function?
BR
#4 Posted : 18 February 2017 13:18:48(UTC)
PompelmoTell
The method 2, of course, no; the method 1 yes, but get only one solution.
You can also use the internal function, "solve", or the plugins.
Search on the forum the plugins "nonlinearsolvers" and "maxima". Allow to extend the solution of nonlinear equations (reading the discussions can also highlight some limitations highlighted by users).
#5 Posted : 18 February 2017 18:48:24(UTC)
Read the first example carefully. 'solve' is inaccurate on long range
but the initial is good enough to reduce the brackets. Wise to check
with accurate 'Dichotomy'.
Forum Solve.sm (16kb) downloaded 41 time(s).
#6 Posted : 19 February 2017 01:51:12(UTC)
"roots" is a great solving companion:
solve explicit & solve general intersection.
Solve roots.sm (13kb) downloaded 51 time(s).
Offline mdominiak
#7 Posted : 20 February 2017 09:42:21(UTC)
mdominiak
Rank: Member
Poland
Thanks for help.
