SMath Studio Forum
Questions
Combobox with Variable Selection
Is it possible to create a combobox that has a variable matrix. Meaning if x use Y matrix, else use Z matrix. See attached. I have 2 matrices. Depending on what is selected from a different combobox I'd like to change the matrix that the next combobox uses. I understand that I can put the "if statement" between the comboboxes but this doesn't look as clean Thanks in advance! Combobox List - variable matrix.sm (11kb) downloaded 95 time(s).Edit_1: Note - If actually using this for Masonry the if statement is incorrect. This doesn't matter for the question at hand though Edited by user 13 March 2017 00:14:01(UTC)
| Reason: See Edit_1
But actually you have the if statement, right before the first combobox; how it is more clean? If you use a line() on MMCS, then you can place MMCS:MMCS out of the right margin after the first combobox making it available for the 2nd combobox. If you need to reuse it, you can define MMCS as a function MMCS(MUM), and then you can define MMCS:MMCS(MUM) after the first combobox (below or out of the printing bounds) |
SMath Studio Forum
Questions
