4 Pages«<234
Offline Alex M.
#61 Posted : 15 October 2016 01:55:41(UTC)
Alex M.
Was thanked: 113 time(s) in 86 post(s)
Good Day Davide,
I have used the "Field" functionality for a while now, in particular the "date" and the "worksheet info".
I have noticed that:
1. worksheet info field does not change if the actual smath file properties change
2. date changes the moment smath worksheets is re-opened
Is there a particulat reason for this behaviour? If you consider my suggestion worthwhile I propose to update the worksheet info fields every time the .sm file is opened to scan for changes. Also I propose to update the "date" field only when it is created or copied/cloned elsewhere - it would make sense to track the date when a particular calculation page in a .sm worksheet was created, not the current date/time at the instance of .sm file access.
A.M.
Edited by user 15 October 2016 02:04:53(UTC)  | Reason: Not specified
#62 Posted : 16 October 2016 18:58:06(UTC)
Was thanked: 852 time(s) in 564 post(s)
Hello Alex,
Yes, this is because the region is designed to have a low footprint and there isn't an event "File Properties Changed" for the worksheet; but I see that it doesn't changes even on file opening nor for region paste; I'll investigate it ASAP.
I suppose is matter of my habits; if I need a static date/time I write it directly or I convert the field to static text. However I realize that one might want it "less dynamic". What if I add a property for each field to drive the update? (whenever possible or just manual by context menu).
Edited by user 16 October 2016 19:05:58(UTC)  | Reason: Not specified
Best regards,
Davide
If you like my plugins please consider making a donation to SMath Studio
on 17/10/2016(UTC)
Offline Alex M.
#63 Posted : 17 October 2016 19:06:03(UTC)
Alex M.
Originally Posted by: Davide Carpi Go to Quoted Post
Hello Alex,
Thank you, Davide, both tweaks will be very much welcome, if and when you have time, of course.
thanks 1 user thanked Alex M. for this useful post.
on 18/10/2016(UTC)
#64 Posted : 02 November 2016 20:57:10(UTC)
PLUGIN UPDATED SMath Studio 0.98.5935 and later
  • Rendering logic refactored to be much more fast (smooth worksheet's scroll on huge regions or even on multiple regions intersecting the viewport);
  • Applied correction on characters' spacing to make them closer to common text editors;
  • Fields: added option to disable automatic updates;
  • Fields: fixed Worksheet's metadata not updated on file open/region paste;
  • Spell checker import tool: dictionary packages now are loaded directly (no needs to unpack them);
  • minor fixes;
  • refactoring;
  • documentation updated;
Edited by user 02 November 2016 21:16:41(UTC)  | Reason: Not specified
Best regards,
Davide
thanks 3 users thanked Davide Carpi for this useful post.
on 02/11/2016(UTC),  on 02/11/2016(UTC),  on 04/12/2016(UTC)
#65 Posted : 12 January 2017 18:12:34(UTC)
PLUGIN UPDATED SMath Studio 0.98.6179 and later Beta
  • fixed performances issues on print preview;
  • added overline style (CTRL+SHIFT+O);
  • fixed text color change vs fields;
  • minor fixes;
  • refactoring;
Best regards,
Davide
on 12/01/2017(UTC),  on 12/01/2017(UTC),  on 13/01/2017(UTC)
Offline ElSid
#66 Posted : 03 March 2017 22:41:07(UTC)
ElSid
United States
Was thanked: 5 time(s) in 5 post(s)
Davide,
Under version 0.98 build 6179 (64 bit) loaded, this plugin does not work as it used to. It used to be that CTR+Shift+W would pop open a "formatting" dialog box (per post #2 "floating toolbar"Wink like the text region utilities. Now it just opens a "text box which is the width of the sheet, but no formatting utilities. Is this because 64 bit loaded up when I upgraded?
PS Same issue with portable version I created with previous version. Can shis toolbar be placed in the side panel with the math/symbols, etc.?
PPS If I left mouse click and go to settings, the floating toolbar pops up. Is there a way to make this the default? (both desktop and portable)
Edited by user 03 March 2017 22:56:23(UTC)  | Reason: Not specified
#67 Posted : 04 March 2017 02:55:19(UTC)
Originally Posted by: ElSid Go to Quoted Post
Davide,
Under version 0.98 build 6179 (64 bit) loaded, this plugin does not work as it used to. It used to be that CTR+Shift+W would pop open a "formatting" dialog box (per post #2 "floating toolbar") like the text region utilities. Now it just opens a "text box which is the width of the sheet, but no formatting utilities. Is this because 64 bit loaded up when I upgraded?
Really strange Umnik
Only cases in which you should notice changes are on cleaning of settings folder (but this will load the default settings, that aren't the ones listed by you) or by your choice. Please check your settings in the "More..." > "Options..." menu ("New regions" and "Environment" tabs). Settings should be saved once you click on "OK" and never change, except in cases mentioned previously.
Nope. Since next SS relase should be possible to create plug-ins to have more toolboxes, but this won't be the place for Writer Region toolbars.
Edited by user 04 March 2017 03:31:56(UTC)  | Reason: Not specified
Best regards,
Davide
on 04/03/2017(UTC)
#68 Posted : 08 March 2017 14:13:00(UTC)
  • [critical] Fixed blue bleeding worksheet on history UnDo after deleting regions;
  • [critical] Fixed regions saved as empty when data pasted on canvas and no more edited;
Edited by user 08 March 2017 14:15:37(UTC)  | Reason: Not specified
Best regards,
Davide
on 08/03/2017(UTC),  on 08/03/2017(UTC)
#69 Posted : 08 March 2017 15:36:53(UTC)
Was thanked: 448 time(s) in 341 post(s)
My procedure Win 7, micro laptop:
1. from the insert menu => click the W symbol [insert writer region]
2. the empty rectangle appears [|]
3. click right for the drop down menu => click left "settings"
4. as you start typing in the rectangle the movable tool bar is active.
Offline Alex M.
#70 Posted : 08 March 2017 17:28:07(UTC)
Alex M.
Thank you for a prompt fix, Davide.
on 09/03/2017(UTC)
Offline ElSid
#71 Posted : 17 March 2017 16:57:52(UTC)
ElSid
United States
Jean,
That is the problem! The movable tool bar is active only after doing all that. It used to pop up @ step #1.
#72 Posted : 17 March 2017 17:21:16(UTC)
Have you tried to change your settings?
Edited by user 17 March 2017 17:22:54(UTC)  | Reason: Not specified
Best regards,
Davide
on 17/03/2017(UTC)
Offline ElSid
#73 Posted : 17 March 2017 18:29:35(UTC)
ElSid
United States
Environmental --> Popup toolbar --> On new region.
I just did a fresh install and the setting is sticking. Need to confirm on my portable version later tonight as I left my drive at home ...
thanks 1 user thanked ElSid for this useful post.
on 17/03/2017(UTC)
#74 Posted : 18 March 2017 04:21:52(UTC)
That is the problem!The movable tool bar is active only after doing all that.It used to pop up @ step #1.
Once you have entered the writer region you have minimal options:
click on a word to Ctrl+B, Ctrl+U [bold, underline].
For the tool bar: click right, click left on 'settings'.
The minimal and advanced options is very ergonomic [to me].
4 Pages«<234
