Offline chandragon
#1 Posted : 29 March 2017 12:08:24(UTC)
chandragon
France
Hi everyone !
I'm new to SMath Studio and find it really great, thanks a lot for this awesome tool !
But I came across a problem I don't find how to solve:
I want to export my data (a big matrix) to a csv file that would be arranged like this:
0.01,201060,237680,198853.285077439
0.015849,143256,185072,174269.293182435
0.025119,93978,149668,133006.974667634
0.03981,57338,110334,83471.8795836333
0.063095,35432,79992,43221.3253258427
0.1,20672,57000,19652.9918548953
0.15849,11280.4,40188,8399.57161545733
0.25119,6361.6,27224,3544.56326448012
For that, I use a matrix to which I add the colums one by one and use the CVS/ODT plugin:
M:=augment(col1;col2)
M:=augment(M;col3)
M:=augment(M;col4)
export_CSV(M,"filename"Wink
And that works fine up to 4 columns... but for a reason I don't understand if I add more columns it ends up writing the file as:
"mat(0.01,201060,237680,198853.285077439,0.015849,143256,185072,174269.293182435,0.025119,93978,149668,133006.974667634......
Can you help me get the same file format with more columns ?
Thanks !
Edited by user 31 March 2017 13:53:22(UTC)  | Reason: Not specified
#2 Posted : 29 March 2017 13:48:02(UTC)
Was thanked: 1323 time(s) in 873 post(s)
Hello chandragon Offline
could you provide a file with an example that doesn't work for you, I'm not able to reproduce your issue
Edited by user 30 March 2017 19:39:07(UTC)  | Reason: fixed image
#3 Posted : 29 March 2017 18:58:37(UTC)
Was thanked: 980 time(s) in 808 post(s)
Originally Posted by: chandragon Go to Quoted Post
For that, I use a matrix to which I add the columns one by one
Give some hint about your matrix:
1. created in Smath as an 2D image ?
2. columns from foreign source or from Smath modules ?
If foreign from source as individual columns
easy to augment via a little piece of program.
Offline chandragon
#4 Posted : 31 March 2017 12:43:35(UTC)
chandragon
France
Hi and thanks for your answers.
Giving you the .sm file would be complicated because of the plenty of files it opens...
But here is the output file I get:
mydata.7z (5kb) downloaded 35 time(s).
If I remove the " " and try to read it with rfile it gives the value 0.
The matrix I write is pretty big but here is what it looks like when I want to show it:
The number of lines matches.
It is created via a succession of augment() of columns made of real and imaginary parts of complex arrays that are created line by line in a for loop, example for one of them here:
Offline chandragon
#5 Posted : 31 March 2017 13:53:00(UTC)
chandragon
France
Problem solved using only one augment() call to create the matrix like Davide Carpi did!
Thanks again !
#6 Posted : 01 April 2017 00:57:12(UTC)
Your collection is not a matrix; it is an MDA [Multi Dimensional Array => Matlab]
or a CELL ARRAY [Mathematica]. No matter, the "collection" can be spooled to file
and recalled from file, just do it the right way as exemplified [attached].
File Create.sm (25kb) downloaded 49 time(s).
... you can't remove the quotes "..."
