Excellent tool for electric engineering.
Must have portable software on your USB key. Symbolic calculations is a great value for electronics.
more...
by Igor Skarine
Thanks Andrey Ivashov for this wonderful tool that you provided.
It is designed very well and the best opensource alternative to MathCAD available.
more...
by Walter
Thank you Andrey Ivashov for developing this wonderful software, as well as all the people who contribute with solutions day after day. As a university professor, I must say that the use of SMath Studio has contributed greatly to improve the way of transmitting and sharing knowledge.
more...
by Eduardo Palma Zambrano
Edited by user 26 May 2017 00:43:13(UTC)
on 26/04/2017(UTC), on 26/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 28/04/2017(UTC), on 29/04/2017(UTC)
Originally Posted by: Andrey Ivashov Built-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet; Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards) Edited by user 28 April 2017 13:37:08(UTC)
Joined: 28/04/2017(UTC) Posts: 2 Was thanked: 1 time(s) in 1 post(s)
Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location. The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
Originally Posted by: letzm Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi. I guess you have to remove image region plugin. |
1 user thanked letzm for this useful post.
Joined: 15/04/2012(UTC) Posts: 1,985 Was thanked: 1124 time(s) in 721 post(s)
Clear() doesn't work with vectorize(), whereas IsDefined() does. It is not really essential to have that feature but the response indicates successful execution, which is wrong. Clear.sm (30kb) downloaded 50 time(s). |
Hello Martin, Clear(,)=1 looks a Matlab code that clears the work space from previous assigned values. Thus, it renders the algorithm of the "work space" scalar wrt their respective scalar running iterators x, y ... In the attached "Fourier Quantum"... x,y are returned scalar only for the double integrator. The Mathcad double integrator is coded implicit of 'x,y' scalar ... much simpler but less educative. Jean Fourier Quantum CoC Copy.sm (98kb) downloaded 57 time(s).
