The integral of 1/(ln(x) with limits of x from 2 to 1000 does not agree with mathlab or maxima -- The numerical value of the following integration is off -- should be 176.56 and Smath gives 177.1 Any idea what could be the problem? Thanks Joey Ooi
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,639 Location: Italy Was thanked: 1323 time(s) in 873 post(s)
Hello
Joey Ooi
, You have to set a better accuracy in the global options (tools >> options >> calculation) |
Thank you for your quick and accurate response Davide. It was very helpful indeed. Best regards Joey
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Originally Posted by: Joey Ooi Any idea what could be the problem? Smath Simpson iterative integrator is known to range from exact [sometimes] to poor. Increasing accuracy is fine in this example but will not converge in other instances like in the Fourier Quantum double integral. You can rescue your example using the attached Romberg. Mathematica online integrator link added. Jean Integrate Mathematica.sm (10kb) downloaded 26 time(s).
... like this
How many numerical integrators have been imagined ? 1+1+1+... Even Mathcad aren't so easy to deal with. This visit is worth the time spent. Jean Fourier Quantum CoC Model.sm (37kb) downloaded 17 time(s).
