Thanks for all the work you have put into this software!
I was wondering if you could make a function to round the value up. So round 2.2 up to 3. Or a function to round down or round to nearest 5... etc. Would be helpful when I am calculating the required number of items required and get 2.2 back, I need it to be 3 when I cannot have a partial item.
Thanks!
Originally Posted by: Destory I was wondering if you could make a function to round the value up. So round 2.2 up to 3. Or a function to round down or round to nearest 5... etc. Would be helpful when I am calculating the required number of items required and get 2.2 back, I need it to be 3 when I cannot have a partial item.
Thanks! How can maths invent that 2.2 could be/should be 5 ? From the fx menu, scroll down to Ceil and plug your 2.2 in ... = 3 You could probably square the circle for 2.2 => 5
Hello Destory, Apart from the Ceil function, you can write your own function for this, i have made an example for you: you can edit the function (extra if loop) if you want it to handle negative numbers differently. ceil_and_roundup_to_5.sm (8kb) downloaded 433 time(s).I hope this helps you. regards, csb Edited by user 24 May 2017 00:14:45(UTC)
| Reason: sorry can't upload image?
The image:
