Hi, is it possible to set up interval for the function, which i want to figure in X-Y plot? For example with using if-else or something different. I need to figure only some interval but when i zoom in or zoom out the SMath will stop working. Thank you for your help. Edited by moderator 26 June 2017 10:51:48(UTC)
| Reason: marked as SOLVED by report
Joined: 23/12/2011(UTC) Posts: 318 Location: italy Was thanked: 109 time(s) in 93 post(s)
Yes, it is possible. You can find in the forum different examples like the one I attach to you but also with other modes like if-else. Regards sergio
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Observe the blanking character "
