11 Pages«<91011
#201 Posted : 07 March 2017 18:55:24(UTC)
Was thanked: 590 time(s) in 397 post(s)
The download link in my signature for the portable version with maxima now works again.
Portable SMath with plugins and interactive handbook: http://smath.info/wiki/SMath%20with%20Plugins.ashx
on 07/03/2017(UTC),  on 07/03/2017(UTC)
Offline Alex M.
#202 Posted : 08 March 2017 02:49:31(UTC)
Alex M.
Was thanked: 113 time(s) in 86 post(s)
I am being directed to this login page:
https://extmoodle.th-bra...nburg.de/login/index.php
Offline bdrunagle
#203 Posted : 08 March 2017 11:48:21(UTC)
bdrunagle
Rank: Member
Was thanked: 10 time(s) in 4 post(s)
Thanks for that Alex, that's where I'm being directed too - I thought I was doing something wrong!
Brian
#204 Posted : 08 March 2017 12:04:58(UTC)
Was thanked: 862 time(s) in 574 post(s)
You must register before. On the page header you can change the language (BTW I've updated the link on the wiki to access using the english interface)
2017-03-08 10_05_10-Externe Lernplattform TH Brandenburg_ Log in to the site.png
Best regards,
Davide
If you like my plugins please consider making a donation to SMath Studio
on 08/03/2017(UTC)
Offline Tim Gowing
#205 Posted : 16 May 2017 23:26:32(UTC)
Tim Gowing
United Kingdom
Hello forum,
I found SMath last week via Martin Kraska's Calculix page: https://github.com/mkraska/CalculiX-Examples.
Thank you Martin, thank you Andrey Ivashov; I've been looking for a math worksheet for several years, I'm not sure how I missed your fantastic program.
I'm reading the book by Bernard Liengme and have become interested in using the Maxima plugin.
I receive an error when following Maximaplugin from http://en.smath.info/list/plugins:
http://en.smath.info/vie...e68-e32b5badce41/summary
I have 0.98.6179 working using mono in Ubuntu 16.10; it's really impressive.
Is the Maxima plugin compatible with 0.98.6179 / mono / Linux?
Tim
Offline Tim Gowing
#206 Posted : 17 May 2017 00:38:21(UTC)
Tim Gowing
United Kingdom
I have now worked out how to use the plugin online gallery.
Thank you for reading
Tim
#207 Posted : 17 May 2017 14:27:57(UTC)
Originally Posted by: Tim Gowing Go to Quoted Post
Hello forum,
Tim
The Maxima plugin doesn't work under Linux.
On my support page I provide a portable windows installation with maxima pre-configured (follow the link in my signature). It is based on 0.98.6179. The plugin doesn't work with 0.98.6325.
Offline Tim Gowing
#208 Posted : 17 May 2017 16:49:22(UTC)
Tim Gowing
United Kingdom
Martin,
Thank you for your link to the portable version of SMath, I'll give that a go.
Also, I really appreciate the wealth of Calculix techniques and examples that you provide.
kind regards,
Tim
Offline Tim Gowing
#209 Posted : 18 May 2017 21:18:38(UTC)
Tim Gowing
United Kingdom
I have installed the regular Windows x64 version 0.98 (build: 6179) and have installed the Maxima Plug-in from the online gallery.
Upon opening SM I get the following warning:
I don't see how to remove or update the plug-in (CoolProps plug-in updated ok).
Maybe I have overlooked a step?
Tim
Offline bdrunagle
#210 Posted : 18 May 2017 21:52:35(UTC)
bdrunagle
Rank: Member
Confirmed for me also with 0.98 6179 and Windows 8 x64.
Brian
#211 Posted : 19 May 2017 00:05:51(UTC)
Was thanked: 460 time(s) in 353 post(s)
Click on "Close", here is Smath eager to run.
Same happened to me after few weeks of running fine
w/o this unexplained error message. It might be enough
to remove from the directory and re-download ?
#212 Posted : 19 May 2017 00:17:09(UTC)
Tim
What do you mean by "regular version"? Is it the portable version from my support page at THB?
The Maxima plugin isn't easy to configure, therefore I compiled the portable distribution (see link in the signature) which should run out of the box (from an usb stick or whatever directory where you dump the archive), including the interactive handbook (try the [?] button in the tool bar). It should work with Win7.
Problems with win10 have been reported. As I run just win7, there is not much I can do about it.
For full functionality of the maxima plugin, the 2014 version of the portable distribution should be used (at the cost of loosing great new SMath features). Basic problem is that in the meantime the integrate function has been protected against being taken over by 3rd party plugins. You can still use Maxima for integration but that involves workarounds and exceptions, see the interactive handbook for details.
Once the portable distribution is installed (unpacked) you can update the other plugins but don't touch SMath and the maxima plugin.
#213 Posted : 11 July 2017 00:37:39(UTC)
The Maxima plugin is under maintenance again. Thanks to Andrey and Davide, who made adjustments to API changes and helped me with getting started in Visual Studio and C#.
For now, I have made the most urgent fixes.
Todo:
- More testing
- Cleanup (remove obsolete stuff)
- Update Maxima
The plugin is not yet updated in the online gallery. If you want to try it with the current beta SMath (0.98.6398) then you can download the plugin from the gallery and exchange the dll by the attached one (in the zip file).
Plugin Maxima Test.sm (259kb) downloaded 17 time(s).
Plugin Maxima Test.pdf (934kb) downloaded 32 time(s).
MaximaPlugin.zip (65kb) downloaded 19 time(s).
thanks 4 users thanked mkraska for this useful post.
on 11/07/2017(UTC),  on 11/07/2017(UTC),  on 11/07/2017(UTC),  on 12/07/2017(UTC)
Similar Topics
news for Maxima Plugin (Questions)
by oscampo 27/01/2016 18:39:35(UTC)
Maxima plugin error (Bugs & Problems)
by olik 30/11/2015 10:17:28(UTC)
11 Pages«<91011
