lcesero Offline
#1 Posted : Tuesday, May 01, 2012 2:42:08 PM(UTC)
lcesero
I have come across an error when doing the folowing calculation.
-5.00+.85+.85+3.30=-4.44*10^-16 ( decimal places are set to 2)
The above equation should equal zero.
I am using the portable version .93 (build 4466 ) on Windows 7 Pro 64bit.
Thanks in advance.
lcesero Offline
#2 Posted : Tuesday, May 01, 2012 9:11:55 PM(UTC)
lcesero
I was wondering if anyone else can reproduce this symptom.
Thanks,
smath Offline
#3 Posted : Tuesday, May 01, 2012 9:21:12 PM(UTC)
smath
Rank: Administration
Groups: Administrators
Was thanked: 218 time(s) in 120 post(s)
Hello lcesero.
Yes, I've reproduced it. The only thing I can do here is to add an ability to replace answer with 0 if the result accuracy is less then or equal . This way used by Mathcad as an option of every equation. Will think about it.
Best regards, Andrey Ivashov.
Edited by user Tuesday, May 01, 2012 9:30:00 PM(UTC)  | Reason: Not specified
