New SMath Studio 0.94.4523 Stable available Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book). SMath Studio Desktop on the Desktop (Windows) SMath Studio Desktop on the Desktop (Linux) Last changes - Picture Region improved to support scaling and read-only mode;
- Picture Region improved to be automatically fitted to the page width on Picture insert if page layout specified;
- Added support for colors specifying for the special objects and strings into the Plot Region using web format (like #6699CC);
- Function sum(1) now built-in to the program;
- Continue and Break statements implemented.
- Area Region improved to support multi-language feature for the Area titles;
- Added ability to set title for the Separator Region;
- Descriptions can be now used not only for Math Regions but for any evaluable regions like Plot Region;
- Pound-mole (lbmol) built-in Unit added;
- Added ability to start SMath Studio in silent mode using '-silent' argument next to the list of worksheet files to process files without starting SMath Studio GUI;
- Handling of arguments separator keying improved in Math Region;
- Added ability to add a new cell to the vector/system/line by keying arguments separator;
- Error handling corrected to indicate whether it is not possible to define element of the nested arrays using el(..) function;
- Unit conversion corrected when working with operations like (1/a)^b -> 1/a^b;
- Default Text Region font name now don't exported to .sm/.smz file saving;
- Several critical/calculation issues fixed usually appeared on complex units evaluation;
- Fixed issues when Description of the evaluable region become empty after file save/load cycle.
- Fixed issue when undesirable brackets appeared sometimes around the pasted math expressions;
- Fixed critical error of Text Region appeared sometime on Cut/Backspace operations;
- Fixed error tooltip location issue when Region for the tooltip located between two Collapsed Areas;
- Fixed issue when Separator cannot be moved by the mouse;
- Fixed error appeared in some cases when big numbers processed with symbolic engine ("xE" error);
- Fixed error appears for min/max functions when working with zeros and other values that includes units;
- Fixed issue when it was impossible to use trailing zeros option for zero results;
- Fixed issue when some functions are shown twice in the Insert Function dialog;
- Fixed critical error appeared on removing of empty cell from the vector/system/line functions if nested matrix/system/line exists there;
- Critical error appears on Region remove if the Region focused and located after the collapsed Area fixed;
- Fixed Region's selection error appeared sometime on fast mouse clicks;
- Fixed new Region painting issue if a Region added to the top left corner of the Worksheet;
- Fixed error of defining matrix elements using symbolic optimization;
- Fixed critical error appears on evaluation if manually assigned result Units contains any math error;
- Fixed simplification errors of the boolean operators related to wrong sign of the result expression;
- Fixed errors of the operations with matrices and scalars in symbolic library;
- Examples improved;
- Refactoring.
Changes since SMath Studio 0.94 - Critical error fixed appeared on changing Description language of the set of evaluable Regions when one or more Regions in the set has no Description at all;
- Calculation errors fixed in symbolic library for the following expressions: sin(atan(x)), cos(acot(x)), tan(asin(x)), tan(acos(x)), cot(asin(x)) and cot(acos(x));
- Working with multi-language enabled Text Regions improved;
- Resizing of the Picture fixed;
- Critical error appears on operator keying fixed;
- Product function button on the right panel fixed;
- Sum function button on the right panel repaired to insert sum(4).
Framework: .NET Framework 2.0
- Desktop (Linux):
Interface languages Desktop and Handheld (34 languages): [BEL] Belarusian / Беларуская [BUL] Bulgarian / Български [CAT] Catalan / Català [CHS] Chinese (Simplified) / 简体中文 [CHT] Chinese (Traditional) / 簡體中文 [CPP] Portuguese (Brazil) / Brazil (Português) [CZE] Czech / Čeština [DAN] Danish / Dansk [DUT] Dutch / Nederlands [ENG] English / English [FAS] Persian / فارسی [FIN] Finnish / Suomi [FRE] French / Français [GER] German / Deutsch [GRE] Greek / Ελληνικά [HEB] Hebrew / עברית [HUN] Hungarian / Magyar [IND] Indonesian / Bahasa Indonesia [ITA] Italian / Italiano [LAV] Latvian / Latviešu [LTH] Lithuanian / Lietuvių [NOR] Norwegian / Norsk [POL] Polish / Polski [POR] Portuguese / Português [RON] Romanian / Română [RUS] Russian / Русский [SCC] Serbian (Latin) / Srpski [SCR] Croatian / Hrvatski [SLK] Slovak / Slovenčina [SPA] Spanish / Español [SRP] Serbian (Cyrillic) / Српски [SWE] Swedish / Svenska [TUR] Turkish / Türkçe [UKR] Ukrain / Українська
Free Download
Note: No current version of SMath Studio Handheld release will be introduced. Please use the latest stable handheld version (0.90).
Tutorial SMath Studio tutorial by Bernard Liengme.
- SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
on 21/05/2012(UTC), on 21/05/2012(UTC), on 21/05/2012(UTC), on 22/05/2012(UTC)
Joined: 15/05/2012(UTC) Posts: 14 Location: Profeta Miqueas Oe10-309 y Tabiazo Was thanked: 7 time(s) in 4 post(s)
Thanks for fixing the pi product function and for using sum(4) instead of sum(1) in the right-hand side palette. |
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University. |
- unfortunately not possible to delete an imported picture
+ picture scale works fine
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,639 Location: Italy Was thanked: 1323 time(s) in 873 post(s)
Originally Posted by: noxx - unfortunately not possible to delete an imported picture
+ picture scale works fine i've not seen your issue... i can delete imported images without problems... |
