Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Thank you Alex, it's the same issue reported here, I'll try to fix it tomorrow |
Fix committed for the latest SS BETA; I'm aware there are still some drawing issues with cases due to something in SMath Studio itself. |
There is a problem with at() in build 7219: It seems that the function at() isn't executed. Materials E7-6.sm (11kb) downloaded 29 time(s).
SMath Studio: SMath Studio Desktop 0.99.7219.26345 portable, 64-bit OS: Microsoft Windows NT 6.1.7601 Service Pack 1; Windows 7 Professional Service Pack 1, 64-bit Screen: 1920x1080 px, 96x96 dpi, 96 GP.CDPI Localization: language=GER; dec.symbol=<comma>; arg.separator=<semicolon>; OS dec.symbol=<comma>; OS arg.separator=<semicolon>; OS d.g.separator=<period> Framework: CLR 4.0.30319.42000
installed versions: v2.0.50727 2.0.50727.5420 SP2 v3.0 3.0.30729.5420 SP2 v3.5 3.5.30729.5420 SP1 v4 Client 4.7.02053 Full 4.7.02053 v4.0 Client 4.0.0.0
Plugins: - [AppDir] Area Region - 0.99.7219.26345 - [AppDir] HTMLFileType - 1.14.7219.26345 - [AppDir] ImageFileType - 1.11.7219.26345 - [AppDir] Math Region - 0.99.7219.26345 - [AppDir] PictureRegion - 1.10.7219.26345 - [AppDir][DISABLED] PieChartRegion.dll - 1.0.7097.30323 - [AppDir] PlotRegion - 1.11.7219.26345 - [AppDir] SMath Viewer Files Plugin - 1.1.7219.26385 - [AppDir] SMathFileType - 1.11.7219.26345 - [AppDir] SpecialFunctions - 1.12.7219.26345 - [AppDir] SpecialFunctions - 1.12.7219.26345 - [AppDir] StandardToolboxButtons - 1.1.7219.26345 - [AppDir] TextRegion - 1.11.7219.26345 - [AppDir] XMCDFileType - 1.12.7219.26345 - [UserDir] ALGLIB® - numerical analysis library - 1.0.7175.33522 - [UserDir] Checkbox Region - 1.0.7097.23234 - [UserDir] CheckBoxList Region - 1.0.7097.29767 - [UserDir] Combobox Region - 0.1.7097.23243 - [UserDir] ComboBoxList Region - 1.0.7097.29780 - [UserDir] Conditionally Formatted Label - 1.0.7100.19488 - [UserDir] Custom Functions - 1.1.7200.16172 - [UserDir] Custom Glyphs - 1.1.7200.16176 - [UserDir] Data Exchange - 1.1.6858.3747 - [UserDir] Development Tools - 1.0.6974.21980 - [UserDir] DotNumerics - 1.1.7166.24796 - [UserDir] EFI for SMath Studio - 1.0.7165.40625 - [UserDir] Excel Files Plugin - 1.3.7100.21176 - [UserDir] Excel Input-Output Functions - 1.0.7165.25287 - [UserDir] FFTPACK - 1.0.6825.4311 - [UserDir] FIR Filter Design - 1.0.7165.39130 - [UserDir] GNU Scientific Library (GSL) - 1.0.7165.41516 - [UserDir] GPC Wrapper - 1.0.6824.41024 - [UserDir] Hyperlink Region - 1.0.7105.20106 - [UserDir] Image Region - 2.99.7100.21996 - [UserDir] include - 0.2.7165.16642 - [UserDir] Intel ODE Solver Library - 0.1.7164.40868 - [UserDir] Mathcad File Access Functions - 1.0.6983.32721 - [UserDir] MaximaPlugin - 1.98.7100.23756 - [UserDir] Modeller Region - 1.0.7100.42534 - [UserDir] MS Chart Region - 0.1.7164.40842 - [UserDir] Nonlinear Solvers - 1.1.7097.23301 - [UserDir] Numeric Up-Down Region - 1.0.7100.21168 - [UserDir] ODE Solvers - 0.2.7155.3312 - [UserDir] ODE Solvers - 0.2.7155.3312 - [UserDir] PDF Files Plugin - 1.0.7097.27694 - [UserDir] RadioButtonList Region - 1.0.7097.30330 - [UserDir] Run - 0.2.6975.39277 - [UserDir] Slider Region - 1.0.7100.22009 - [UserDir] Snapshot Region - 1.0.7100.22017 - [UserDir] Statistical Tools - 1.0.6824.32561 - [UserDir] Table Region - 0.2.7097.29803 - [UserDir] TeX File Type - 0.2.7097.30337 - [UserDir] Text Region Utilities - 0.4.7200.15920 - [UserDir] Writer Region - 0.22.7200.15900 - [UserDir] XlsxImportExport - 1.3.6996.39330 - [UserDir] X-Y Plot Region (JXCharts) - 0.2.7198.38915 - [UserDir] X-Y Plot Region (JXCharts) - 0.2.7198.38915
Thank you Martin, I will look at it as soon as I can. edit: fixed in later versions SSEdited by user 16 May 2020 15:33:00(UTC)
In the attached sheet, the conversion of solution results into definitions is demonstrated in two ways: 1. Usage of Assign(), a function made for this purpose in the Maxima plugin. 2. Usage of the substitution function at() from custom functions plugin, which by syntax should be good for the purpose. It turns out that it makes a difference whether the Solve function is inside a line block or not. In the latter case, at() comes up with a strange error message. Solve-3.sm (21kb) downloaded 31 time(s). |
PLUGIN UPDATED SMath Studio 0.99.7251 Nightly Build and later - Unknowns() improved to don't match integration variable of int(4); Unknowns.sm (19kb) downloaded 25 time(s).Edited by user 16 May 2020 15:26:02(UTC)
PLUGIN UPDATED SMath Studio 0.99.7691 Nightly Build and later- [ SS-4651] at() assignment improved to avoid unexpected substitutions when variables are given as replacements; EDITeither this should works correctly now: Originally Posted by: mkraska In the attached sheet, the conversion of solution results into definitions is demonstrated in two ways: 1. Usage of Assign(), a function made for this purpose in the Maxima plugin. 2. Usage of the substitution function at() from custom functions plugin, which by syntax should be good for the purpose.
It turns out that it makes a difference whether the Solve function is inside a line block or not. In the latter case, at() comes up with a strange error message. Edited by user 12 March 2021 12:52:09(UTC)
on 06/03/2021(UTC), on 06/03/2021(UTC)
Davide, thanks for developing this plugin; I use several function in here regularly. One that I just tried using that could be very useful for me is the Ceil function. In engineering we often want to always round up, so this would fit that bill well. However, it seems to only round up with respect to the base unit instead of the unit actually used. So instead of rounding a result up to the next inch (or millimeter), it rounds to the next foot (or meter). Would it be possible to account for the unit in that evaluation somehow? Thanks, Jason |
Originally Posted by: Jason McCool Davide, thanks for developing this plugin; I use several function in here regularly. One that I just tried using that could be very useful for me is the Ceil function. In engineering we often want to always round up, so this would fit that bill well. However, it seems to only round up with respect to the base unit instead of the unit actually used. So instead of rounding a result up to the next inch (or millimeter), it rounds to the next foot (or meter). Would it be possible to account for the unit in that evaluation somehow? Thanks, Jason
Such a function would definitely need the target unit as input. In order to use this for display automatically, the plugin would need to suppress back-simplification to SI, which might require "Optimization None" on user side. A comprehensible operator form might put a placeholder for the unit at the index position to the lower left ceil2.sm (4kb) downloaded 14 time(s). |
Yes, that looks like it will do what I need. Good idea, Martin. Thanks! And I like the idea of being able to define the output unit in the index position. That seems clear and streamlined as well. |
Originally Posted by: mkraska useful, consistant, I like it... agreed. I'll add it in the next plugin update. Edited by user 27 March 2021 18:51:55(UTC)
| Reason: typo |
PLUGIN UPDATED SMath Studio 0.99.7739 Nightly Build and later- added Ceil(2);
- added Floor(2);
4 users thanked Davide Carpi for this useful post.
on 27/03/2021(UTC), on 27/03/2021(UTC), on 28/03/2021(UTC), on 29/03/2021(UTC)
Davide, Since you are using a specialized output with the brackets and unit subscript, I would like to suggest ceil2 using a superscript for the unit. floor2 keeps the current subscript. Visually, this will help us "SEE" what was used in context to the equation/function
Originally Posted by: ElSid Davide, Since you are using a specialized output with the brackets and unit subscript, I would like to suggest ceil2 using a superscript for the unit. floor2 keeps the current subscript. Visually, this will help us "SEE" what was used in context to the equation/function I get the point but seems to me that might be confusing when exponentiations are involved Also, the "base" could be a variable, or a simple number Edited by user 15 April 2021 13:04:35(UTC)
Was thanked: 21 time(s) in 17 post(s)
Hi! The var2str from custom functions plugin has problems with the new release: Code:appVersion(4)="0.99.7808.230"
var2str(1.7,2)="1,70"
var2str(1.7,"0.00")="0002E02"
var2str(1.7,"0,00")="0002C02"
Yes, this is related to changes in text encoding, I'll fix it ASAP. |
PLUGIN UPDATED SMath Studio 0.99.7808 and later- fixed encoding/decoding issues;
- refactoring;
on 22/05/2021(UTC), on 22/05/2021(UTC)
Davide, I encountered this issue after the last update sergio
1 user thanked PompelmoTell for this useful post.
Confirmed. I'll fix it ASAP. |
What about if you specify Bolean completely ?
