#1 Posted : 27 September 2013 03:32:23(UTC)
Was thanked: 854 time(s) in 566 post(s)
SMath up to 0.96.4909 > password: test
SMath 0.97.5301 or later > Beta
link a variable in the placeholder and left-click on the region to export the variable to the clipboard (clipboard's content can be pasted in spreadsheets or text editors - can't be used as variable in SMath)
Also, you can paste spreadsheets data directly in the region placeholder.
PLEASE REPORT HERE ANY ISSUE
Best regards,
Davide
Edited by user 14 July 2014 10:56:46(UTC)  | Reason: Not specified
Best regards,
Davide
If you like my plugins please consider making a donation to SMath Studio
on 27/09/2013(UTC),  on 27/09/2013(UTC)
Offline sublim21
#2 Posted : 27 September 2013 17:36:27(UTC)
sublim21
Was thanked: 3 time(s) in 3 post(s)
looking great websurfer. Looks like you're all about the extensions now.
Offline omorr
#3 Posted : 27 September 2013 19:13:04(UTC)
omorr
Rank: Administration
Groups: Registered, Administrators, Advanced Member
Serbia
Was thanked: 259 time(s) in 223 post(s)
Thanks Davide Good
Try to reproduce this one
A:=something(2)
where something() is not defined. This will crash Smath for me.
Edited by user 27 September 2013 19:15:00(UTC)  | Reason: Not specified
omorr attached the following image(s):
on 28/09/2013(UTC)
#4 Posted : 27 September 2013 19:22:55(UTC)
Thank you both, I'll check the issue Good
Btw as I've written in another topic I hope that a "copy special" and a "paste special" will be implemented natively in smath, from context menu (and maybe from shortcuts, like ctrl+ shift +c to make the "external copy" )". Since that day I hope this plugin will help.
Edited by user 27 September 2013 19:31:54(UTC)  | Reason: edit
Best regards,
Davide
#5 Posted : 28 September 2013 17:17:25(UTC)
Originally Posted by: omorr Go to Quoted Post
Thanks Davide Good
A:=something(2)
fixed & updated
[edit] working to add both import and export features
Edited by user 29 September 2013 00:21:25(UTC)  | Reason: Not specified
Best regards,
Davide
on 28/09/2013(UTC)
#6 Posted : 29 September 2013 15:54:33(UTC)
UPDATED
- added "import data"
Best regards,
Davide
Offline experimentator
#7 Posted : 10 March 2014 10:30:22(UTC)
experimentator
Rank: Member
Spain
After installing the ClipboardRagion pluging Smath displays the error as follows.
I have neither the possibility of deleting nor re-installing.
Edited by user 10 March 2014 10:33:01(UTC)  | Reason: Not specified
experimentator attached the following image(s):
Learning by doing
#8 Posted : 10 March 2014 10:59:22(UTC)
Was thanked: 583 time(s) in 394 post(s)
Just search for the dll and remove the associated folder structure, typically "some cryptic name/some version number". Currently that is the only way to remove plugins.
It may help to locate the settings directory using the function SettingsDirectory(). There you find folders extensions/plugins, where the above-mentioned plugin directories reside.
Portable SMath with plugins and interactive handbook: http://smath.info/wiki/SMath%20with%20Plugins.ashx
#9 Posted : 10 March 2014 11:24:30(UTC)
experimentator
Rank: Member
Spain
Danke Martin, it works, but I cannot install the extension again, occurs the same problem.
Learning by doing
#10 Posted : 10 March 2014 11:45:58(UTC)
That's because the Clipboard Region plugin has not yet been updated to SMath Studio 0.97 (there were API changes). Also there might be problems in actually doing the update (Davide reported problems with clipboard handling).
on 10/03/2014(UTC)
#11 Posted : 10 March 2014 13:45:02(UTC)
Exactly, as for now this plugin works only with SMath up to 0.96.4909; a new plugin will be relased when Andrey will fix the issues in the clipboard interface.
Best regards,
Davide
Edited by user 10 March 2014 14:00:30(UTC)  | Reason: Not specified
Best regards,
Davide
#12 Posted : 10 May 2014 17:06:51(UTC)
Don't know exactly what is the default behavior for plugins uploaded before the introduction of the target version in the Extensions Menager, this plugin should be not visible; anyway it is just a transitory issue...
Edited by user 10 May 2014 17:09:26(UTC)  | Reason: Not specified
Best regards,
Davide
on 10/05/2014(UTC)
#13 Posted : 14 July 2014 11:00:08(UTC)
UPDATED SMath 0.97.5301
- Updated to fit recent API changes;
- fixes;
- New features: paste inside placeholder;
Be sure to have the "Exclude beta-versions" unchecked
Edited by user 14 July 2014 11:01:53(UTC)  | Reason: Not specified
Best regards,
Davide
on 14/07/2014(UTC),  on 14/07/2014(UTC)
