#1 Posted : 14 March 2014 02:40:44(UTC)
Was thanked: 854 time(s) in 566 post(s)
Password: test
As for now, do not use this plugin for productivity Beta
- Allowed inputs: mouse click, mouse wheel, + and - keys;
- Settings: double-click over the region.
- Input: any vector/matrix/system with two or more rows.
- Output: place a variable in the region placeholder.
- Size driven by the values (manual resize not allowed).
- Adds the same control in SMath Viewer (using the same layout).
Look in the attachment for more details and features.
SMath Studio 0.96.5146 or later required
PLEASE REPORT HERE ANY ISSUE
Edited by user 25 May 2014 16:29:51(UTC)  | Reason: Not specified
File Attachment(s):
features & examples.sm (19kb) downloaded 84 time(s).
Best regards,
Davide
If you like my plugins please consider making a donation to SMath Studio
thanks 5 users thanked Davide Carpi for this useful post.
on 14/03/2014(UTC),  on 14/03/2014(UTC),  on 14/03/2014(UTC),  on 14/03/2014(UTC),  on 14/03/2014(UTC)
Offline PompelmoTell
#2 Posted : 14 March 2014 12:14:26(UTC)
PompelmoTell
Was thanked: 29 time(s) in 23 post(s)
Thanks Davide for the great job
I don't mind using the two-column matrix; In some situations is a nice shortcut for define the variable in output.
Perhaps it would be useful to differentiate the instrument through an option.
Offline zorrykid
#3 Posted : 14 March 2014 15:00:18(UTC)
zorrykid
Rank: Member
Was thanked: 4 time(s) in 4 post(s)
Thanks a lot and best regards
Franco
#4 Posted : 14 March 2014 15:29:48(UTC)
Originally Posted by: ioan92 Go to Quoted Post
Thanks Davide for this exquisite gift,Clapping
It really fills a missing tool place ! Yes
You're welcome Biggrin
I noticed that when a matrix is taken as input source, the output is no more the selected line number,
but it corresponds to the value for the selected line in the second column of this matrix. Unsure
From my viewpoint, it would be preferable to have as output always the selected line number, in order to be able to recover the whole line of the matrix, especially when the matrix has more then 2 columns (!?).
Ok, I can easily suppress this feature, I've just reproduced the combobox behavior Good
No feedbacks about the new symbolic features shown in the first attachment?
Best regards,
Davide
Best regards,
Davide
on 14/03/2014(UTC)
#5 Posted : 14 March 2014 18:41:44(UTC)
PompelmoTell
In the previous post I had not yet used the example.
now, more than before, I can confirm that two-column matrix is fantastic for me Clap
#6 Posted : 14 March 2014 20:53:00(UTC)
Was thanked: 583 time(s) in 394 post(s)
Great to see that you have access to the math region formatting capabilities within custom regions.
Given the depth of your insight into the machinery, I see potential for great things to become true:
- plot regions with placeholders for axis limits and arbitrary expressions for annotation
- Text region with math insets and rtf formatting capabilities
- seamlessly integrated matrix editor
- Tabular input feature (like in Mathcad)
- Tabular display using math-region-consistent formatting
- advanced result formatting (numbers of significant digits, polar form of complex numbers)
- special markup for nonscalar variables (boldface)
- Fulltext search (in the open sheet and in directory trees)
But don't be too fast, even now it is hard to keep up documenting... ;-)
Portable SMath with plugins and interactive handbook: http://smath.info/wiki/SMath%20with%20Plugins.ashx
on 14/03/2014(UTC)
#7 Posted : 14 March 2014 23:02:24(UTC)
I've updated the plugin, now the output is always the item number; thinking a little while about it, my opinion is that the default output should be this... I'll think if and how to introduce a choice to the output (the ordinal number rather than the whole row or an element in a column...)
best regards,
Davide
Edited by user 14 March 2014 23:05:45(UTC)  | Reason: Not specified
Best regards,
Davide
on 14/03/2014(UTC)
#8 Posted : 15 March 2014 00:04:25(UTC)
I do not really understand the problem with the return values taken from the second column of a matrix. If the line number is the desired output, just fill the second column with appropriate numbers or access the complete line via findrows().
on 15/03/2014(UTC)
#9 Posted : 15 March 2014 03:15:17(UTC)
Thank you Martin, this is true Good
From my point of view there are enough tools to make any solution usable, but there are "better" and "less better" ways.
Talking about general cases, with the first approach (emulation of combobox behavior) if you want the index from a matrix for post-processing purposes (get the whole row, get the n-th element of that row, or get something else not directly related), you need a pre-processing by assigning the first column to a new variable or some post-processing operation (like that made by you with findrows; here you assume that the second column contains only different values, but you may encounter some problems when the second column contains several equal values).
In the other hand making the option index as output always available there's no needs to make pre-processing operations and any post-processing operation could start from an unique identifier without issues; moreover, as I've written in my previous post, I think that it's possible to move the most common desired outputs directly inside the region dialog (if my explaination was not too much confused, it should emerge that these options are for a very specific context, namely that in which the region drives only the parameters of the input matrix; if the region drives also other things, like corresponding parameters in other matrices/tables, the index is again the most important thing). As "secondary" matter, this is a more linear approach: any allowed input returns as default output the row index of the selected item).
However the plugin is a beta and I'm opened to any suggestion Laugh wild
Best regards,
Davide
Edited by user 15 March 2014 03:30:39(UTC)  | Reason: Not specified
Best regards,
Davide
on 15/03/2014(UTC),  on 15/03/2014(UTC)
#10 Posted : 15 March 2014 09:53:50(UTC)
Yes, perhaps it is a good idea to have a choice in the settings (radio button?) of what the output should be (row index, column number, where to get the value, complete row...).
Now something different. The discussion on parametrization of smath sheets "from below" caused me to have a closer look on what Andrey calles "absolute definitions", see http://en.smath.info/for...bsolute-definitions.aspx
If an absolute variable is used as output, then the radio button region fails to trigger re-calculation, even if it looses mouse focus. In contrast to that, normal variables react imediately to button actions.
In order to get the sheet consistent, manual recalculation is required.
File Attachment(s):
Parametrierung.sm (5kb) downloaded 24 time(s).
on 15/03/2014(UTC),  on 16/03/2014(UTC)
#11 Posted : 15 March 2014 18:44:07(UTC)
I think that absolute definitions could be useful also in the modeller region Good
Seems a SMath bug or "unimplemented feature"... if you use a classic variable as output (a) and then you define the absolute variable using the output (∼a:a), the result is the same...
I change, by the program, the Input Data source for the Button List and, for every input change, the setting "split every" is reset to the default "all the list"(!?).
The layout and the number of consecutive elements are unset when you change the input size (number of rows)
As for the layout, there are no problems... The "split every" value is a little bit more complicated to drive...
Do you imagine a font control for the list. As it is, it seems using an embedded unique font, without any possibility of changing ?
Actually there are some small issues in Math regions when you change the fonts (you can see something exporting the example worksheet in SMath Viewer), but is it in my plans...
best regards,
Davide
Edited by user 16 March 2014 02:00:10(UTC)  | Reason: Not specified
Best regards,
Davide
on 15/03/2014(UTC)
Offline Andrey Ivashov
#12 Posted : 18 March 2014 00:36:24(UTC)
Rank: Administration
Was thanked: 1022 time(s) in 386 post(s)
I think plug-in should be recompiled. Sorry for this, but I have to do some critical changes in Custom Regions mechanizm in order to provide new features in future.
on 18/03/2014(UTC),  on 18/03/2014(UTC)
#13 Posted : 18 March 2014 02:24:02(UTC)
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features;
Don't worry Andrey, any improvement is highly welcome! (and the plugin version in the EM is very useful to avoid confusion) Good
Best regards,
Davide
Edited by user 18 March 2014 14:11:55(UTC)  | Reason: new update
Best regards,
Davide
#14 Posted : 18 March 2014 14:13:52(UTC)
UPDATED
- Layout & split settings propagated when data size changes;
- fixed clicks on "white cells";
- fixed clicks on empty regions.
Edited by user 18 March 2014 14:22:51(UTC)  | Reason: Not specified
Best regards,
Davide
#15 Posted : 22 March 2014 20:33:50(UTC)
UPDATED
- SMath Viewer: uses the region description (if exist and is shown).
Best regards,
Davide
on 22/03/2014(UTC)
#16 Posted : 15 April 2014 14:41:15(UTC)
UPDATED
  • BTS SS-103 features (extended)
    - select input column
    - select output type (index, element from a column, whole row)
    - select text Font
    - select text Color (from SMath toolbar)
  • RBs now uses MathRegions for any element shown (except strings at the first nesting level)
  • Added number's formatting (at the first nesting level)
NOTE: The plugin should be back-compatible with the previous version; this compatibility will be extended as long as possible but I suggest to update any document containing this plugin to avoid problems in the future.
Edited by user 15 April 2014 14:42:53(UTC)  | Reason: Not specified
Best regards,
Davide
#17 Posted : 15 April 2014 18:40:35(UTC)
Grazzie mille !Smile
de rien! Biggrin
BTW this version of the plugin should be the backbone of the ComboBoxList plugin (SS-102) so any feedback about bugs or lacks is important.
Best regards,
Davide
Best regards,
Davide
on 16/04/2014(UTC)
#18 Posted : 18 April 2014 20:26:24(UTC)
UPDATED
- fixed number's settings when dialog exit condition is not "OK";
- minor changes;
Best regards,
Davide
#19 Posted : 19 April 2014 10:40:31(UTC)
Hi Ioan, happy Easter to you Good
With my files I can't reproduce this issue, can you attach here or send me a file with this issue?
Best regards,
Davide
edit: this is a back-compatibility issue. Anyone that experiment this problem can replace with a text editor the XML code:
Code:
      <ul>
        <li>a string</li>
        <li>a string</li>
        <li>a string</li>
        <li>a string</li>
      </ul>
with:
Code:
      <ul>
        <li>#</li>
      </ul>
then the file can be opened and saved again, without losses.
Edited by user 19 April 2014 16:05:31(UTC)  | Reason: Not specified
Best regards,
Davide
on 19/04/2014(UTC)
#20 Posted : 08 April 2015 10:53:26(UTC)
PLUGIN UPDATED
- Plugin updated to respect changes in SS Core;
- Evaluation on end of multiple MouseWheel calls or +/- keys pressed restored;
- +/- fixed to work with any localization;
Edited by user 08 April 2015 11:23:16(UTC)  | Reason: Not specified
Best regards,
Davide
on 09/04/2015(UTC)
