Nightly build: SMath Studio 0.97.5283 available - SS-143: Freezing of the application fixed on some copy/paste operations;
- Fixed removing of Regions based on RegionHolder when placeholder is empty;
- Fixed issue when useless brackets appeared between operands;
- Insert Unit dialog improved to allow displaying properties as dimensions if defined.
Download Edited by user 06 July 2014 23:43:33(UTC)
on 19/06/2014(UTC), on 19/06/2014(UTC), on 19/06/2014(UTC), on 20/06/2014(UTC), on 21/06/2014(UTC), on 21/06/2014(UTC), on 21/06/2014(UTC)
Joined: 15/04/2012(UTC) Posts: 1,985 Was thanked: 1124 time(s) in 721 post(s)
The new version affects the image region, see issue SS-165. Are there changes required by design or is that an unintended collateral effect? |
Andrey, method UnitInfo.GetCurrentUnitName() was removed from ioman.dll (SMath.Manager.UnitInfo class) and what to do now? It was used in the include plugin. EDIT: UnitsManager.GetCurrentUnitName() ? Edited by user 23 June 2014 10:42:01(UTC)
Originally Posted by: uni UnitsManager.GetCurrentUnitName() ? Yes, it is correct. Best regards.
Joined: 19/11/2013(UTC) Posts: 17 Was thanked: 1 time(s) in 1 post(s)
I can't download the file.
Originally Posted by: hpf_br I can't download the file. What file you can't download?
Originally Posted by: smath Originally Posted by: hpf_br I can't download the file. What file you can't download? I can't download SMathStudioDesktop.0_97_5283.Setup.msi it returns: Server Error in '/' Application.
Really strange, works for me (now and even yesterday)... OS: Win 7 x64 Browsers: Chrome, Firefox, Firefox (using DownThemAll extension) tried also using a proxy service (anonymouse.org) Edited by user 02 July 2014 10:29:26(UTC)
Originally Posted by: hpf_br I can't download SMathStudioDesktop.0_97_5283.Setup.msi it returns: Server Error in '/' Application. Thank you for the info! Could you please try to download file again? I think I found the reason and just fixed it. Please let me know about results. Best regards, Andrey Ivashov.
