Updated. Now you can also use simple form for D() function definition. |
4 users thanked uni for this useful post.
on 06/12/2018(UTC), on 06/12/2018(UTC), on 06/12/2018(UTC), on 06/12/2018(UTC)
But x in D(t,x) is vector. |
on 24/12/2018(UTC), on 24/12/2018(UTC), on 24/12/2018(UTC), on 24/12/2018(UTC)
Updated. Rkadapt() fixed. |
3 users thanked uni for this useful post.
on 16/01/2019(UTC), on 16/01/2019(UTC), on 16/01/2019(UTC)
Updated ( >= SMath Studio 0.99.6970). Changes: - divided into two plugins (the second one is Intel ODE Solver Library); - version changed (0.2.x.x); - refactored. Edited by user 01 February 2019 04:01:14(UTC)
Some news. It's hard but I want to realize a general solution for some types of tasks. Specially for this I need more powerful symbolic engine inside SMath. Therefore I made symcs project. I hope that we can use this solution in other similar cases. That's why I split the plugin. |
on 11/02/2019(UTC), on 11/02/2019(UTC)
I think that most of the Mathcad users know what you intend to do and I really appreciate that Regards, Radovan |
Originally Posted by: omorr I think that most of the Mathcad users know what you intend to do and I really appreciate that Viacheslav is an ancient Mathsoft visitor. I still have a document from Him ... 2D Implicit plot. Is possible to code 1/1 Mathcad Given/ODEsolve ?
No, Jean, 1/1 - not possible. Now they have two different realisations: MC11-MC15 and Prime. But I can do something similar. Plugin can implicity collect information about available ode solvers and you can choose them in the context menu. |
Originally Posted by: uni No, Jean, 1/1 - not possible. Now they have two different realisations: MC11-MC15 and Prime. But I can do something similar. Plugin can implicity collect information about available ode solvers and you can choose them in the context menu. I can see you "busy" ! Gorgeous context menu. What is that Smath Community doing: Building Cathedrals/Pyramids ? You mean: Mathcad Prime "cluster fuck" in US appreciation from Collab.
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Originally Posted by: uni Some news. It's hard but I want to realize a general solution for some types of tasks. Specially for this I need more powerful symbolic engine inside SMath. Therefore I made symcs project. I hope that we can use this solution in other similar cases. Hi uni. It is possible to enable a clone of that component for return only the expressions inside? For example, the set of the equations Also, it is possible too to add the option for mark with a round box the area? Best regards. Alvaro.
Coming soon, but for now as an experiment. |
on 26/11/2021(UTC), on 29/11/2021(UTC)
I have verified that linear interpolation is used, which is described in the manual. I changed the interpolation method to linear and also changed the notation of the derivative by analogy ( "`" ). |
Prime symbol looks much better (′). I think it's better to use it. |
I was wrong. Linear interpolation and linear spline interpolation are different things. I will try to find the formulas that are used in these functions. |
A simple test that shows the interpolation method used by the ODE solver. Obviously, the lspline() function is used. Odesolve() with rkfixed method (Mathcad 15). Odesolve interpolation test.mcd.zip (9kb) downloaded 7 time(s).The same for Mathcad Prime 7.0 (Adams method used). Edited by user 29 November 2021 09:15:42(UTC)
Ok, I found a bug in rkfixed() and finally figured out the difference between interpolation functions. In the picture below, I repeated part of the calculations from Mathcad. As you can see, to interpolate the numerical solution of the ODE, a cubic spline is used, linear at the end points. Bugs will be fixed when the build server starts working. Links: 1. Cubic spline2. Cubic Spline Interpolation Cubic spline interpolation using Mathcad (2009).pdf (257kb) downloaded 39 time(s).Edited by user 30 November 2021 04:37:19(UTC)
Originally Posted by: uni Ok, I found a bug in rkfixed() and finally figured out the difference between interpolation functions. In the picture below, I repeated part of the calculations from Mathcad. As you can see, to interpolate the numerical solution of the ODE, a cubic spline is used, linear at the end points. Thanks Viacheslav ... superb demo. BTW, I was wrong ODEsolve is lspline MCD 11. Years ago, Tom G. had exposed the different deficiencies wrt to each l_p_c cubic spline ... Matlab as well. So, your next headache is to figure the best solver from the huge Smath library [17], Mathcad stiff is Radau MCD 2001i, 11. Cheers ... Jean.
Originally Posted by: Jean Giraud BTW, I was wrong ODEsolve is lspline MCD 11. This day should be accepted as a milestone. We have to celebrate this day annually. There should be carnivals, fireworks should enlighten the night.
