SMath Studio Forum
Samples
Non Iterative & Signum-based Iterative methods
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,639 Location: Italy Was thanked: 1323 time(s) in 873 post(s)
Non iterative methods for root estimation + iterative methods based on the sign(1) function for finding roots and maximum/minimum values in a range. Signum-based Iterative methods.sm (186kb) downloaded 33 time(s).Edited by user 17 May 2016 01:28:10(UTC)
on 16/05/2016(UTC), on 17/05/2016(UTC)
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Thanks Davide ... that will make my day ! I discovered the "GID" transit integrator in Mathcad 11. Works as well in Smath. Don't know if other CAS support ? Then: like this Jean
BTW: Nobody @ PTC Mathcad Community has seen "GID" integrator, PTC and Jean ended "warflame" years ago before "GID" [just too bad].
... in your last example: there is a missing 0 and an extra min/max
Originally Posted by: Jean Giraud ... in your last example: there is a missing 0 and an extra min/max True, thank you Jean Usually it may need to play a little with bounds and intervals. In this case changing intervals from 40 to 41 fixed the issue. (updated the first post) Edited by user 16 May 2016 18:49:32(UTC)
SMath Studio Forum
Samples
