Offline Andrey Ivashov
#1 Posted : 20 May 2016 01:01:31(UTC)
Rank: Administration
SMath Studio 0.98.5983 available
Latest changes (against SMath Studio 0.98.5973)
  • SS-2346: Handling of text strings to paste into the worksheet improved;
  • Changing size of matrix inside the element of output matrix disabled in order to fix critical error happened in such cases;
  • Added ability to select answer of math expression with manually set unit;
  • SS-2318: Corrections made, see Preprocessing of symbolic data / functions' arguments for details;
  • Cloud: Scrolling to top on every key down issue fixed.
Download
thanks 6 users thanked Andrey Ivashov for this useful post.
on 20/05/2016(UTC),  on 20/05/2016(UTC),  on 20/05/2016(UTC),  on 20/05/2016(UTC),  on 21/05/2016(UTC),  on 22/05/2016(UTC)
Offline tomtit
#2 Posted : 25 May 2016 19:21:51(UTC)
tomtit
The attached sample doesn't work with the latest build 5983, but worked fine with all previous versions.
It indicates error x - not defined. Actually x is dummy, it was used as a place-holder for symbolic calculation.
cic3.sm (5kb) downloaded 60 time(s).
