Offline gurro
#1 Posted : 01 February 2017 04:18:44(UTC)
gurro
Was thanked: 20 time(s) in 7 post(s)
I typed a long SMath Studio file using the latest stable version. After saving the file, and re-opening I get a red bar and missing half of my document. Is there any way to recover it? It has happened to me at least three times since I loaded the last version of SMath Studio. I had produced PDF files from my other files, so I didn't worry much. But this one I spent a long time typing and didn't printed it to PDF before closing it. HELP! Good
Example4.1.1_4.1.3.sm (2,011kb) downloaded 21 time(s).
Edited by moderator 09 July 2017 18:33:19(UTC)  | Reason: marked as FIXED
#2 Posted : 01 February 2017 10:15:37(UTC)
There was an empty region in the file with missing end tag. Deleting the highlighted line solves the problem.
The problem is reproducible if you create an empty text region (typing " ) and then save the file.
2017-02-01 08_08_49-Example4.1.1_4.1.3.sm - SciTE.png Example4.1.1_4.1.3_Kr.sm (2,011kb) downloaded 15 time(s).
Edited by user 01 February 2017 10:20:57(UTC)  | Reason: Not specified
on 01/02/2017(UTC),  on 01/02/2017(UTC)
#3 Posted : 01 February 2017 16:31:02(UTC)
As I opened the work sheet, the scroll bar didn't report red dot,
only a red | in the empty text box. True: past | empty.
An interesting document as I did some work on "nanofiltration NF 200"
Offline Andrey Ivashov
#4 Posted : 04 February 2017 00:41:17(UTC)
Rank: Administration
Fixed. Thank you!
