Offline ndtma
#1 Posted : 03 February 2017 11:34:27(UTC)
ndtma
Sri Lanka
The attached image shows different results in symbolic optimization in using Vetorize Operator, and
consequently generates an error when using "FindRoot" function in the attached worksheet.
When Equations 1B & 2B are disabled and 1A & 2A enabled, "FindRoot" gives the result.
Vectorize error - Symbolic Optimization.sm (190kb) downloaded 25 time(s).
Edited by moderator 03 February 2017 13:34:26(UTC)  | Reason: Not specified
Offline PompelmoTell
#2 Posted : 03 February 2017 12:07:35(UTC)
PompelmoTell
if you initialize the vector Q, then it works
Q:mat(el(Q,1),el(Q,2),el(Q,3),el(Q,4),4,1)
thanks 2 users thanked PompelmoTell for this useful post.
on 03/02/2017(UTC),  on 03/02/2017(UTC)
Offline ndtma
#3 Posted : 03 February 2017 12:42:52(UTC)
ndtma
Sri Lanka
Thank you! It works.
#4 Posted : 03 February 2017 18:11:43(UTC)
Your red vectorise is just a display, i.e: not an assignment.
Unlike the "red vectorise", the "blue vectorise" ASSIGNS the
vector required by FindRoots, thus immaterial wrt Symbolic/Numeric/NONE
The suggestion to initialise is not technical to me [just a comment].
It simply confuses matters. There is a long route to explore/clarify
the Smath Vectorise operator
