Definition of range3 is incorrect in SMath. The correct definition should read range 3 returns a vector that starts at number 1 and ends at number 3 with an increment of number 2 minus number 1. Number 2 and 3 have been interchanged.
Hello
JoeF
Originally Posted by: JoeF Definition of range3 is incorrect in SMath. The correct definition should read range 3 returns a vector that starts at number 1 and ends at number 3 with an increment of number 2 minus number 1. Number 2 and 3 have been interchanged. There's no error. The argument enumeration for any function in SMath Studio is given in the input order (the one you can see even by pasting the math as plain text); accidentally in range(3) the glyph has the three arguments in a row with the 3rd one in the middle, hence probably the confusion range(1,2,3) -> Edited by user 23 March 2017 20:58:13(UTC)
Thanks Davide - I get it now Joe Edited by moderator 24 March 2017 20:37:04(UTC)
| Reason: marked as SOLVED - title edited
