SMath Studio Forum
Bugs & Problems
Puzzling Nested Program within eval(,)
These two documents are set with same [M=100, p=150] so that you can enjoy this beautiful Julia image. The puzzle is wrt the nested program within eval(,). It may have interest for the Designers. Otherwise, Julia may be the sole instance even encountered in your Smath sessions. If you set [M=200, p=300], you will get a much bigger image [2hrs here !] At that setup, you will get a more complete 2D plot [augment(J1,J2)], that you can save for your evening visitors, while enjoying Vodka ! I can't explain what Julia:=eval(program) is doing in there. Jean Pattern Julia wfile Complex [YES].sm (29kb) downloaded 18 time(s). Pattern Julia wfile Complex [NOT].sm (30kb) downloaded 15 time(s).
SMath Studio Forum
Bugs & Problems
