Offline Destory
#1 Posted : 23 May 2017 21:40:33(UTC)
Destory
United States
Thanks for all the work you have put into this software!
I was wondering if you could make a function to round the value up. So round 2.2 up to 3. Or a function to round down or round to nearest 5... etc. Would be helpful when I am calculating the required number of items required and get 2.2 back, I need it to be 3 when I cannot have a partial item.
Thanks!
#2 Posted : 23 May 2017 22:36:03(UTC)
Thanks!
How can maths invent that 2.2 could be/should be 5 ?
From the fx menu, scroll down to Ceil and plug your 2.2 in ... = 3
You could probably square the circle for 2.2 => 5
Offline csb531
#3 Posted : 24 May 2017 00:10:52(UTC)
csb531
Rank: Member
Netherlands
Hello Destory,
Apart from the Ceil function, you can write your own function for this, i have made an example for you:
example
you can edit the function (extra if loop) if you want it to handle negative numbers differently.
ceil_and_roundup_to_5.sm (8kb) downloaded 432 time(s).
I hope this helps you.
regards,
csb
Edited by user 24 May 2017 00:14:45(UTC)  | Reason: sorry can't upload image?
Offline csb531
#4 Posted : 24 May 2017 00:18:43(UTC)
csb531
Rank: Member
Netherlands
The image:
#5 Posted : 26 May 2017 04:43:25(UTC)
Here is the working program for n=5
A bit confusing for n ≠ 5
Utilities Matrix roundup_n.sm (11kb) downloaded 318 time(s).
