Joined: 06/06/2017(UTC) Posts: 5 Location: Lodz Was thanked: 1 time(s) in 1 post(s)
A bar plot is just a bar plot. An "Histogram" is generally plotted "bar", but may be "stem". An 'histogram' comes from a large data set of collected values. Does the attached help ? Jean Stat Histogram PW.sm (52kb) downloaded 39 time(s). Stat Histogram Create Normal Random.sm (70kb) downloaded 44 time(s).
Using the Jean Code. curve_R0.sm (8kb) downloaded 33 time(s).
You could probably attempt fitting a model function. Histograms are difficult to model/fit. Jean Genfit Frechet DIFFICULT.sm (35kb) downloaded 35 time(s).
