Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators:
Administrators
Accuracy problem with boolean operator
Boolean operation fails due to accuracy
janclaeys
12/05/2022 16:05:24(UTC)
5
530
janclaeys
13/05/2022 15:53:18(UTC)
Variables with text in Smath Viewer
Smath Viewer does not change variables that contain text
CBG
28/04/2022 01:27:22(UTC)
0
354
CBG
Solving for Undefined variables, no real roots error
Darcy
25/04/2022 10:13:57(UTC)
9
1,134
26/04/2022 22:11:11(UTC)
String compare problem with different encoding schemes
23/04/2022 00:07:52(UTC)
1
317
25/04/2022 02:00:32(UTC)
bug in matrix function involving a double loop
loha
29/03/2022 18:52:52(UTC)
5
581
30/03/2022 14:09:09(UTC)
bug in if()
immediate evaluation behind line()
MarB
26/03/2022 14:49:18(UTC)
2
444
29/03/2022 12:08:28(UTC)
Special Plots On 2D Plot Bug
Special Plots do not appear when using "if...else" domain argument
Mr. Whiskers
21/03/2022 18:00:29(UTC)
8
638
22/03/2022 17:42:00(UTC)
Error in symbolic evealuation
tomtit
08/03/2022 21:46:17(UTC)
3
435
Razonar
09/03/2022 20:28:24(UTC)
Defining "2:vector" for roots() function Using Submatrix() function
Syntax error while solving roots() function
GabeJ112
03/03/2022 07:55:28(UTC)
2
427
04/03/2022 05:06:12(UTC)
Error copying formulas between worksheets
Jason McCool
24/02/2022 01:40:20(UTC)
12
1,139
Jason McCool
28/02/2022 17:58:22(UTC)
UI not scaled properly on High DPI device
Some issues of High DPI
AZot
21/02/2022 06:12:42(UTC)
0
346
AZot
SineIntegral
SineIntegral
17/02/2022 16:58:40(UTC)
6
603
18/02/2022 03:28:54(UTC)
Error Object reference
TIAGO_ENG2012
17/02/2022 16:28:08(UTC)
18
1,213
TIAGO_ENG2012
18/02/2022 00:03:00(UTC)
Error trying to save to .exe
TIAGO_ENG2012
16/02/2022 19:22:35(UTC)
0
316
TIAGO_ENG2012
erf(x) recalcitrant
erf(x) recalcitrant
13/02/2022 04:00:33(UTC)
0
299
Guest (4)
New Posts |
No New Posts |
Hot Topic (New Posts) |
Hot Topic |
New Posts (Locked) |
No New Posts (Locked) |
Announcement (New Posts) |
Announcement |
Sticky (New Posts) |
Sticky |
Poll (New Posts) |
Poll |
Moved |
