Offline Greg Locock
#1 Posted : 30 August 2009 18:30:01(UTC)
Greg Locock
Please could you make the text boxes resizable and/or multiline.
Offline omorr
#2 Posted : 30 August 2009 19:04:48(UTC)
omorr
Rank: Administration
Serbia
Was thanked: 319 time(s) in 268 post(s)
Hello Greg,
It is actually possible. Multiline text boxes are obtained by CTRL+ENTER at the end of a line. If you want to resize it just click in the box and edit the lines (add some characters, spaces etc.).
Btw., try using different Text and Background collor. At the moment you can not change the existing text. The changes are valid for the subsequent text and expression regions.
There is a simple trick about this, at the moment. You can make a copy of the text or expresion box with the new colors set and delete the old one.
Offline Andrey Ivashov
#3 Posted : 30 August 2009 19:13:57(UTC)
Was thanked: 2011 time(s) in 679 post(s)
Hmm. Could you explain this more detailed? What do you mean "At the moment you can not change the existing text."? This is possible of course.
Offline omorr
#4 Posted : 30 August 2009 19:24:51(UTC)
omorr
Serbia
Ah...yes, Andrey - you are right Confusion , sorry . I did not pay attention. My mistake. There were some comments here abot that and I did not checked latter. I figured out now. Just selecting the text or expression and changing collors will make the things done.
Thank you for this. I would have continued making copies Blush
Sorry again,
Edited by user 30 August 2009 19:27:50(UTC)  | Reason: Not specified
#5 Posted : 30 August 2009 19:29:48(UTC)
No problem, thank you for help.
Btw, to add new line to the Text Control you can use not only Ctrl+Enter. Shift+Enter has same functionality.
Offline omorr
#6 Posted : 30 August 2009 19:44:33(UTC)
omorr
Serbia
Thanks for this information, Andrey Good
One other thing I also missed. The font sizes of one or more regions could be also changed in the same way as colors. Do not know how I missed that Oh my
Offline Greg Locock
#7 Posted : 31 August 2009 15:34:18(UTC)
Greg Locock
Rather than writing thank you for each of these, thank you for explaining. Um, just a wild idea, why not start a wiki for SMath, so you don't have to keep on explaining the same things?
Offline LordMike
#8 Posted : 24 October 2009 03:30:39(UTC)
LordMike
The wiki is there. Go fill it up :P
#9 Posted : 24 October 2009 04:59:04(UTC)
Greg Locock was a first, who have made several pages for the wiki Wink And yes, wiki was his idea...
Offline LordMike
#10 Posted : 24 October 2009 05:13:11(UTC)
LordMike
Heh, my bad if it was badly recieved :P
Offline omorr
#11 Posted : 24 October 2009 16:18:29(UTC)
omorr
Serbia
Do not worry about this, Mike Good . Just do not hesitate to ask about everything you like concerning SMath. Hardly that anything will be badly received Good
