Online Davide Carpi
#1 Posted : 27 September 2013 03:32:23(UTC)
SMath up to 0.96.4909 > password: test
SMath 0.97.5301 or later > Beta
link a variable in the placeholder and left-click on the region to export the variable to the clipboard (clipboard's content can be pasted in spreadsheets or text editors - can't be used as variable in SMath)
Also, you can paste spreadsheets data directly in the region placeholder.
PLEASE REPORT HERE ANY ISSUE
Best regards,
Davide
Edited by user 14 July 2014 10:56:46(UTC)  | Reason: Not specified
thanks 3 users thanked Davide Carpi for this useful post.
on 27/09/2013(UTC),  on 27/09/2013(UTC),  on 05/09/2022(UTC)
Offline sublim21
#2 Posted : 27 September 2013 17:36:27(UTC)
sublim21
Was thanked: 3 time(s) in 3 post(s)
looking great websurfer. Looks like you're all about the extensions now.
Offline omorr
#3 Posted : 27 September 2013 19:13:04(UTC)
omorr
Rank: Administration
Serbia
Thanks Davide Good
Try to reproduce this one
A:=something(2)
where something() is not defined. This will crash Smath for me.
Edited by user 27 September 2013 19:15:00(UTC)  | Reason: Not specified
omorr attached the following image(s):
on 28/09/2013(UTC)
Online Davide Carpi
#4 Posted : 27 September 2013 19:22:55(UTC)
Thank you both, I'll check the issue Good
Btw as I've written in another topic I hope that a "copy special" and a "paste special" will be implemented natively in smath, from context menu (and maybe from shortcuts, like ctrl+ shift +c to make the "external copy" )". Since that day I hope this plugin will help.
Edited by user 27 September 2013 19:31:54(UTC)  | Reason: edit
Online Davide Carpi
#5 Posted : 28 September 2013 17:17:25(UTC)
Originally Posted by: omorr Go to Quoted Post
Thanks Davide Good
A:=something(2)
fixed & updated
[edit] working to add both import and export features
Edited by user 29 September 2013 00:21:25(UTC)  | Reason: Not specified
on 28/09/2013(UTC)
Online Davide Carpi
#6 Posted : 29 September 2013 15:54:33(UTC)
UPDATED
- added "import data"
Offline experimentator
#7 Posted : 10 March 2014 10:30:22(UTC)
experimentator
Rank: Member
Spain
After installing the ClipboardRagion pluging Smath displays the error as follows.
I have neither the possibility of deleting nor re-installing.
Edited by user 10 March 2014 10:33:01(UTC)  | Reason: Not specified
experimentator attached the following image(s):
Learning by doing
#8 Posted : 10 March 2014 10:59:22(UTC)
Just search for the dll and remove the associated folder structure, typically "some cryptic name/some version number". Currently that is the only way to remove plugins.
It may help to locate the settings directory using the function SettingsDirectory(). There you find folders extensions/plugins, where the above-mentioned plugin directories reside.
#9 Posted : 10 March 2014 11:24:30(UTC)
experimentator
Rank: Member
Spain
Danke Martin, it works, but I cannot install the extension again, occurs the same problem.
Learning by doing
#10 Posted : 10 March 2014 11:45:58(UTC)
That's because the Clipboard Region plugin has not yet been updated to SMath Studio 0.97 (there were API changes). Also there might be problems in actually doing the update (Davide reported problems with clipboard handling).
on 10/03/2014(UTC)
Online Davide Carpi
#11 Posted : 10 March 2014 13:45:02(UTC)
Exactly, as for now this plugin works only with SMath up to 0.96.4909; a new plugin will be relased when Andrey will fix the issues in the clipboard interface.
Best regards,
Davide
Edited by user 10 March 2014 14:00:30(UTC)  | Reason: Not specified
Online Davide Carpi
#12 Posted : 10 May 2014 17:06:51(UTC)
Don't know exactly what is the default behavior for plugins uploaded before the introduction of the target version in the Extensions Menager, this plugin should be not visible; anyway it is just a transitory issue...
Edited by user 10 May 2014 17:09:26(UTC)  | Reason: Not specified
on 10/05/2014(UTC)
Online Davide Carpi
#13 Posted : 14 July 2014 11:00:08(UTC)
UPDATED SMath 0.97.5301
- Updated to fit recent API changes;
- fixes;
- New features: paste inside placeholder;
Be sure to have the "Exclude beta-versions" unchecked
Edited by user 14 July 2014 11:01:53(UTC)  | Reason: Not specified
on 14/07/2014(UTC),  on 14/07/2014(UTC)
Offline Reiltar
#14 Posted : 26 August 2022 12:20:27(UTC)
Reiltar
Spain
Hi all,
First of all, sorry for reopening such an old topic but.... hasn't anybody had an issue then trying to import to smath negative values from excel?
Maybe it's related with revision changes in both smath and excel, but when I have negative values I get them imported as text, between quotes "-0.534" i.e
any idea about how to solve that?
Thanks,
Online Davide Carpi
#15 Posted : 29 August 2022 19:18:42(UTC)
I'll check it, thank you for reporting the issue.
on 29/08/2022(UTC)
#16 Posted : 29 August 2022 21:01:06(UTC)
Originally Posted by: Reiltar Go to Quoted Post
"-0.534" i.e
In the mean time it will doctored otherwise.
Offline Razonar
#17 Posted : 29 August 2022 21:36:19(UTC)
Razonar
Uruguay
Hi Davide. Related, though not exactly a plugin question. But since you are going to see the question of the sign in strings, do you know how to specify a negative exponent inside SMath, as in the following example?
Thanks in advance.
thanks 2 users thanked Razonar for this useful post.
on 29/08/2022(UTC),  on 30/08/2022(UTC)
Offline churichuro
#18 Posted : 30 August 2022 02:01:31(UTC)
churichuro
Mexico
Was thanked: 27 time(s) in 22 post(s)
Alvaro an alternative way is
while a better solution is given.
thanks 2 users thanked churichuro for this useful post.
on 30/08/2022(UTC),  on 30/08/2022(UTC)
Offline Razonar
#19 Posted : 30 August 2022 06:36:17(UTC)
Razonar
Uruguay
Hi Churichurro. Thanks, it is a very good workaround, it works, substituting str2num(strrep(STR,"E-","*10^-" ) )
Offline Reiltar
#20 Posted : 01 September 2022 15:25:12(UTC)
Reiltar
Spain
"-0.534" i.e
Thanks for this temporary solution.
