6 Pages«<3456>
Offline uni
#81 Posted : 23 February 2014 13:57:26(UTC)
uni
Yes, it is possible. I didn't update the plugin. I only changed the SMath Studio Desktop exe file.
efi.txt
Edited by user 23 February 2014 14:02:06(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline zorrykid
#82 Posted : 23 February 2014 16:14:14(UTC)
zorrykid
Rank: Member
Thanks a lot for your replay but probably I am doing something wrong.
First of all using the Plugin gallery i downloaded the EFI for Smath Studio..but it was very strange that I didn't find any mcadefi.ddl and USEREFI directory under the plugin dir of my installation of SMath Studio...so I decided to download manually the plugin and install it manually.
Then I downloaded the steamtable for mathcad and moved the 2 files (.ddl) in the USEREFI directory.
But ..no result I do not see listed the steamtable functions and the test file from Martin related to the steamtable functions doesn't work either.
So for sure I have done something wrong , please when you have a moment can you let me know which is supposed to be the correct installation procedure for bot the EFI plugin and the stematable library.
Franco
#83 Posted : 23 February 2014 16:34:20(UTC)
You might try the unofficial portable version (see my signature), it is updated to SMath 0.97. There, the steamtables are installed and ready to use (at least on my system this works).
Thanks to uni for the 32bit-compatible SMath-executable.
Offline zorrykid
#84 Posted : 23 February 2014 17:12:37(UTC)
zorrykid
Rank: Member
I'll do this way thanks and best regards
Franco
Offline tomtit
#85 Posted : 13 March 2014 19:44:46(UTC)
tomtit
This is my remez2.dll. Usually it works a little better than Matlab tools.
You can design FIR band-pass/stop filters up to length~2000.
The example is audiophile's "holy" NPC SM5842 8X interpolating digital filter.
Before starting the program, do not forget to put remez2.dll in the plugin's \userefi folder.
Edited by user 13 March 2014 21:36:18(UTC)  | Reason: Not specified
File Attachment(s):
sm5842.sm (32kb) downloaded 131 time(s).
user_EFI_remez2_dll.zip (5kb) downloaded 136 time(s).
tomtit attached the following image(s):
thanks 1 user thanked tomtit for this useful post.
on 13/03/2014(UTC)
Offline uni
#86 Posted : 18 March 2014 03:00:47(UTC)
uni
SMathStudio_Desktop_0.97.5189_32bit
How to get this 32-bit version (MSVS2010):
Code:
CorFlags /32bit+ SMathStudio_Desktop.exe
Edited by user 20 March 2014 15:19:01(UTC)  | Reason: Not specified
uni attached the following image(s):
Russia ☭ forever
on 21/06/2014(UTC),  on 24/01/2018(UTC)
Offline uni
#87 Posted : 21 June 2014 14:54:52(UTC)
uni
Russia ☭ forever
on 21/06/2014(UTC)
Offline uni
#88 Posted : 08 July 2014 11:21:38(UTC)
uni
Russia ☭ forever
Offline tomtit
#89 Posted : 08 July 2014 20:18:06(UTC)
tomtit
I'm not a programmer, so VS2010 is not a good option. Simple patch is preferable Good.
So far the flags bits are at the same location for all SMath versions.
Just use HEX editor to write one byte 0x03 to absolute address 0x00000218 in the SMathStudio_Desktop.exe.
Good luck !!
Edited by user 08 July 2014 20:19:40(UTC)  | Reason: Not specified
thanks 2 users thanked tomtit for this useful post.
on 09/07/2014(UTC),  on 18/09/2016(UTC)
Offline uni
#90 Posted : 09 July 2014 09:07:38(UTC)
uni
Good
CorFlags attached.
Edited by user 09 July 2014 09:10:04(UTC)  | Reason: Not specified
File Attachment(s):
CorFlags.zip (142kb) downloaded 127 time(s).
Russia ☭ forever
on 18/09/2016(UTC)
Offline uni
#91 Posted : 18 September 2016 08:31:31(UTC)
uni
Updated for the fully automatic build using Release Manager.
Russia ☭ forever
on 18/09/2016(UTC),  on 19/09/2016(UTC),  on 03/12/2016(UTC)
Offline Harvey Hensley
#92 Posted : 30 May 2020 00:00:00(UTC)
Harvey Hensley
Rank: Member
United States
Was thanked: 4 time(s) in 2 post(s)
I am the author of the Prode Physical Properties dll for Mathcad and I am excited to see that it is supposed to work with this extension in SMath. However, I can't seem to get the MathcadEFI installed properly. For example, the digamma function doesn't appear in SMath.
I have a path of C:\Program Files (x86)\SMath Studio\plugins. In the plugins folder is mcaduser.dll, mcadefi.ddl, and userefi folder. The userefi folder contains 4 dlls including mathlib.dll.
From a SMath worksheet, tools>plugins shows that the EFI for SMath Studio is present and enabled, although I had to add to files manually as described above.
Can you help?
Offline uni
#93 Posted : 30 May 2020 01:12:42(UTC)
uni
Mathcad works only with 32-bit plugins but SMath Studio is 64-bit application, so you need to make it 32-bit using CorFlags with administrative privileges.
It is better to use the standard installation method for the plugin.
When the program is running, the mcadefi.log file (located next to the mcadefi.dll) will show the number of loaded functions:
Code:
30.05.2020 03:11:45 [INFO ] [Plugin.Initialize()] OS: Microsoft Windows NT 6.2.9200.0
30.05.2020 03:11:45 [INFO ] [Plugin.Initialize()] .Net: 4.0.30319.42000
30.05.2020 03:11:45 [INFO ] [Plugin.Initialize()] 32-bit
30.05.2020 03:11:45 [INFO ] [Plugin.Initialize()] EFI for SMath Studio, version 1.0.7165.40625, 14-авг-2019 22:34:10
30.05.2020 03:11:45 [INFO ] [Plugin.Initialize()] Psi(1) - ( z ) Digamma function for complex z
30.05.2020 03:11:45 [INFO ] [Plugin.Initialize()] kronecker(2) - ( M,N ) Kronecker product of a square matrix M and a square matrix N
30.05.2020 03:11:45 [INFO ] [Plugin.Initialize()] Successfully. 2 function(s) loaded.
Edited by user 30 May 2020 01:17:02(UTC)  | Reason: Not specified
Russia ☭ forever
on 30/05/2020(UTC)
#94 Posted : 30 May 2020 03:56:46(UTC)
Digamma from series approximation.
Maths Special Polygamma(x).sm (37kb) downloaded 23 time(s).
#95 Posted : 30 May 2020 06:44:16(UTC)
Harvey Hensley
Rank: Member
United States
Hi uni,
I downloaded the CorFlags but I don't understand what I'm supposed to do with the contents. It appears that your example was run from the command line but that didn't work, see below.
C:\Users\Harvey>C:\Users\Harvey>C:\Program Files\SMath Studio>CorFlags.exe /32bit+SMathStudio_Desktop.exe
'C:\Users\Harvey' is not recognized as an internal or external command,
operable program or batch file.
Since I am not a developer, I need some step by step instructions. I have looked through this topic and I don't understand the procedure.
Eventually I hope to get the Prode Properties dll to work.
Sorry to be so clueless.
Offline uni
#96 Posted : 30 May 2020 07:30:16(UTC)
uni
Step 0. Copy CorFlags.exe to the program folder.
Step 1. Start command console with administrative privileges.
Step 2. Move to the program directory:
Code:
cd "c:\Program Files (x86)\SMath Studio"
Step 3. Set the 32-bit flag to 1 (don't forget about spaces):
Code:
CorFlags.exe /32bit+ SMathStudio_Desktop.exe
Step 4. Check the flag value (32BITREQ must be 1):
Code:
CorFlags.exe SMathStudio_Desktop.exe
Result:
Code:
Version   : v2.0.50727
CLR Header: 2.5
PE        : PE32
CorFlags  : 0x3
ILONLY    : 1
32BITREQ  : 1
32BITPREF : 0
Signed    : 0
Command to return back 32-bit flag value (32BITREQ must be 0):
Code:
CorFlags.exe /32bit- SMathStudio_Desktop.exe
Russia ☭ forever
on 30/05/2020(UTC)
#97 Posted : 30 May 2020 15:57:58(UTC)
Harvey Hensley
Rank: Member
United States
Thank you for the clear instructions. I have the EFI working (e.g. kronecker works). However, the prode test file still doesn't work. I'll continue in the Prode Physical Properties thread.
#98 Posted : 30 May 2020 17:35:40(UTC)
... kronecker & Kronecker are built-in native Smath.
#99 Posted : 30 May 2020 18:03:46(UTC)
Harvey Hensley
Rank: Member
United States
For my installation, kronecker only works if the MathcadEFI is enabled.
Offline GerardLardner
#100 Posted : 20 February 2021 23:42:36(UTC)
GerardLardner
Ireland
Was thanked: 4 time(s) in 4 post(s)
Can someone please remind me how to get WaterSteamPro working with SMath? I had it working with my last laptop but I cannot get it working with the new one. I have WSP v6.5; it works fine in Mathcad 15 and in Excel.
I have used the CorFlags app to force SMathStudio_Desktop to work as a 32-bit application (32BITREQ : 1).
I think I must be putting some of the dlls in the wrong folder, as I can't get X-Steam to work either.
  • Which version of mcadefi.dll is needed for the current SMathStudio Desktop?
  • Do I need mcaduser.dll? If so, which version?
  • Which folders should everything (including wspmcad.dll) be in?
Edited by user 20 February 2021 23:55:00(UTC)  | Reason: Not specified
6 Pages«<3456>
