![Greg Locock Greg Locock](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 30/08/2009(UTC) Posts: 52 Location: Australia
Please could you make the text boxes resizable and/or multiline.
![omorr omorr](/forum/resource.ashx?u=274) ![](/forum/Images/Ranks/Administration.png) Rank: Administration Groups: Registered, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740 ![Man Man](/forum/Themes/yafvision/male.gif) ![Serbia Serbia](/forum/Content/images/flags/SP.png) Was thanked: 318 time(s) in 268 post(s)
Hello Greg, Greg Locock wrote:Please could you make the text boxes resizable and/or multiline. It is actually possible. Multiline text boxes are obtained by CTRL+ENTER at the end of a line. If you want to resize it just click in the box and edit the lines (add some characters, spaces etc.). Btw., try using different Text and Background collor. At the moment you can not change the existing text. The changes are valid for the subsequent text and expression regions. There is a simple trick about this, at the moment. You can make a copy of the text or expresion box with the new colors set and delete the old one. Regards, Radovan |
![Andrey Ivashov Andrey Ivashov](/forum/resource.ashx?u=4) ![](/forum/Images/Ranks/Administration.png) Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,636 ![Man Man](/forum/Themes/yafvision/male.gif) ![Russian Federation Russian Federation](/forum/Content/images/flags/RU.png) Was thanked: 2007 time(s) in 677 post(s)
omorr wrote:Btw., try using different Text and Background collor. At the moment you can not change the existing text. The changes are valid for the subsequent text and expression regions. There is a simple trick about this, at the moment. You can make a copy of the text or expresion box with the new colors set and delete the old one. Hmm. Could you explain this more detailed? What do you mean "At the moment you can not change the existing text."? This is possible of course.
smath wrote:omorr wrote:Btw., try using different Text and Background collor. At the moment you can not change the existing text. The changes are valid for the subsequent text and expression regions. There is a simple trick about this, at the moment. You can make a copy of the text or expresion box with the new colors set and delete the old one. Hmm. Could you explain this more detailed? What do you mean "At the moment you can not change the existing text."? This is possible of course. Ah...yes, Andrey - you are right ![Confusion](/forum/Images/Emoticons/sm_confusion.gif) , sorry . I did not pay attention. My mistake. There were some comments here abot that and I did not checked latter. I figured out now. Just selecting the text or expression and changing collors will make the things done. Thank you for this. I would have continued making copies Sorry again, Radovan Edited by user 30 August 2009 19:27:50(UTC)
No problem, thank you for help.
Btw, to add new line to the Text Control you can use not only Ctrl+Enter. Shift+Enter has same functionality.
smath wrote:No problem, thank you for help.
Btw, to add new line to the Text Control you can use not only Ctrl+Enter. Shift+Enter has same functionality. Thanks for this information, Andrey One other thing I also missed. The font sizes of one or more regions could be also changed in the same way as colors. Do not know how I missed that ![Oh my](/forum/Images/Emoticons/sm_ohmy.gif) Regards, Radovan |
Rather than writing thank you for each of these, thank you for explaining. Um, just a wild idea, why not start a wiki for SMath, so you don't have to keep on explaining the same things?
![LordMike LordMike](/forum/resource.ashx?u=408) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 24/10/2009(UTC) Posts: 52 ![Man Man](/forum/Themes/yafvision/male.gif) Location: Denmark
Greg Locock wrote:Rather than writing thank you for each of these, thank you for explaining. Um, just a wild idea, why not start a wiki for SMath, so you don't have to keep on explaining the same things? The wiki is there. Go fill it up :P
LordMike wrote:Greg Locock wrote:Rather than writing thank you for each of these, thank you for explaining. Um, just a wild idea, why not start a wiki for SMath, so you don't have to keep on explaining the same things? The wiki is there. Go fill it up :P Greg Locock was a first, who have made several pages for the wiki ![Wink](/forum/Images/Emoticons/sm_wink.gif) And yes, wiki was his idea...
smath wrote:LordMike wrote:Greg Locock wrote:Rather than writing thank you for each of these, thank you for explaining. Um, just a wild idea, why not start a wiki for SMath, so you don't have to keep on explaining the same things? The wiki is there. Go fill it up :P Greg Locock was a first, who have made several pages for the wiki ![Wink](/forum/Images/Emoticons/sm_wink.gif) And yes, wiki was his idea... Heh, my bad if it was badly recieved :P
LordMike wrote:Heh, my bad if it was badly recieved :P
Do not worry about this, Mike ![Good](/forum/Images/Emoticons/sm_smile_good.gif) . Just do not hesitate to ask about everything you like concerning SMath. Hardly that anything will be badly received Regards, Radovan |
