7 Pages123>»
#1 Posted : 08 March 2015 11:26:21(UTC)
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
WYSIWYG word processing for your worksheets Biggrin
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
TODO LIST
  • Evaluable regions;
  • Styles (full implementation requires API improvements to get/set worksheets properties);
  • RTL/LTR support (see Unicode Bidirectional Algorithm);
  • new/alternative Hunspell wrapper (NHunspell no more updaqted, latest sources not available);
  • tables;
OLD documentation:
Edited by user 13 February 2023 12:30:00(UTC)  | Reason: Not specified
thanks 9 users thanked Davide Carpi for this useful post.
on 08/03/2015(UTC),  on 08/03/2015(UTC),  on 09/03/2015(UTC),  on 09/03/2015(UTC),  on 10/03/2015(UTC),  on 17/01/2016(UTC),  on 03/12/2016(UTC),  on 22/12/2016(UTC),  on 16/11/2018(UTC)
#2 Posted : 08 March 2015 11:37:56(UTC)
Just for developpers
The code contains additional features (style limitations, region's rotation, ...) to use the plugin or the core of this plugin in your projects; let me know if there are issues/bugs to solve or possible improvements.
Examples of use:
- WriterRegion (basics)
- PieChartRegion (multiple regions, fields)
- BarChartRegion (under development)
- SectionRegions [under development]
Edited by user 22 December 2017 14:52:57(UTC)  | Reason: edit PieChart description
File Attachment(s):
WriterManager.sm (12kb) downloaded 286 time(s).
on 08/03/2015(UTC),  on 10/03/2015(UTC)
#3 Posted : 08 March 2015 14:00:52(UTC)
Hello Ioan Good
I know, I've tried a less disturbing "floating toolbar" but I've not (yet) found a good way to handle it (as for now the toolbar is called from the single region and may handle just that region - I have to handle in some way when the region looses the focus or is deleted from the canvas). When Andrey will provides a way to add toolbars from plugins I'll remove completely the form and this issue will be solved Biggrin .
P.S. plugin updated (Math objects vs styles issues)
P.P.S. plugin updated (Copy format for Math objects; Save/read full style settings for empty lines)
Edited by user 08 March 2015 22:01:47(UTC)  | Reason: Not specified
on 08/03/2015(UTC)
#4 Posted : 09 March 2015 22:18:37(UTC)
Hi Davide, thank you for the great plugin.
Here is a preliminary wish-list.
- make the default line spacing customizable or sez it to 1 (this gives grid alignment with the default font setting on my system)
- set the default wrap depending on where the region is inserted. If it is at the left margin, set it to page, if elswhere, set it to custom
- open the hyperlink editor upon double-click on hyperlinks, just as the math editor on math insets.
- if possible, provide a choice, if a sm hyperlink target is to be opened in place of the current document (as with hyperlink text regions) or using the windows run command (leading to a new SMath instance). Currently, the writer region hyperlinks can't be used for interactive handbook cross linking. Thism however, would be very desirable, because they are much easier to edit than the hyperlink text regions.
#5 Posted : 10 March 2015 01:53:23(UTC)
Hello Martin
You're welcome Good
Sure, I think I'll implement the first thing... Also, probably I'll provide the spacing as a paragraph's property, as for the word processors.
That's an interesting idea. It may be matter of taste so I don't know, I have to think a little if should be possible to make it as a customizable option (f.e. my worksheets often are organized in two columns - description on the left and math on the right - thus this approach may be not the best in this or similar cases)
CTRL+SHIFT+H currently does this job (full edit of the hyperlink that surrounds the caret) without interferences with the normal text behaviour (double-click to select and edit/move a word, as for generic word processors); this can be done also from the toolbar button, even if I know is less accessible.
Absolutely yes. I have to know if the function to open the document is available form within plugins or is hardcoded (in this case I'll ask Andrey to make it available)
P.S. PLUGIN UPDATED
- Custom wrap: fixed the size of empty regions;
- Blinking caret;
Edited by user 10 March 2015 02:21:50(UTC)  | Reason: Not specified
#6 Posted : 12 March 2015 16:04:16(UTC)
There is another topic on my wish-list:
Could you please enable the shortcut Ctrl-G for greek letters (for text input and in the math editor)? Currently, you have to type greek letters elsewhere and copy them to the region.
Edit: One more productivity feature: Use ENTER as a shortcut to close the math editor. Then insets can be created without touching the mouse. This way you can easily give math formatting to any cited symbol in the text.
Thanks, Martin.
Edited by user 12 March 2015 16:45:18(UTC)  | Reason: Not specified
#7 Posted : 13 March 2015 12:19:50(UTC)
I think is possible.
Inside the region should be better to have CTRL+G as for the style modifiers (CTRL+B f.e., that enable/disable the bold mode and converts the surrounding/selected word) or like in math regions (just the character before the caret is converted)?
P.S. error found in the greek paragraph of your activebook
Edited by user 13 March 2015 19:58:08(UTC)  | Reason: choosen the first approach
on 14/03/2015(UTC)
#8 Posted : 14 March 2015 20:22:10(UTC)
reproducible (recoverable) crash:
selecting multiple characters and typing (for replacement) produces an exception (index out of range...)
on 15/03/2015(UTC)
#9 Posted : 15 March 2015 11:50:01(UTC)
Reproduced, thank you!
#10 Posted : 15 March 2015 19:59:01(UTC)
PLUGIN UPDATED
- added CTRL+G to swap between latin characters and greek symbols (on selection, on words, on further characters)
- math dialog: added CTRL+G to swap between latin characters and greek symbols (on selection, on further characters)
- math dialog now accepts RETURN and ESC keys;
- hyperlink dialog now accepts RETURN and ESC keys;
- fixed crash on text's replacement;
- fixed objects' focus issues when there are hyperlinks;
- minor changes/improvements;
Edited by user 15 March 2015 21:08:14(UTC)  | Reason: Not specified
thanks 4 users thanked Davide Carpi for this useful post.
on 16/03/2015(UTC),  on 16/03/2015(UTC),  on 16/03/2015(UTC),  on 17/03/2015(UTC)
Offline overlord
#11 Posted : 16 March 2015 16:15:39(UTC)
Turkey
Was thanked: 507 time(s) in 338 post(s)
Is there a reason this region saves a random png data on every change made or is it just junk data? It can easily be detected if you edit *.sm file with a notepad. If you delete this image data then there will be no difference at viewing or printing the document. Moving the region do not add the image data to region. However if you change anything at writer region the png data shall be added again.
Example-2 creates totally the same result on SMath with Example-1, actually Example-2 is notepad modified Example-1.
Example-1:
Code:
<region id="0" left="0" top="0" width="97" height="62" color="#000000" bgColor="#ffffff">
    <writer lang="eng"><![CDATA[<span style="font-family: 'Arial Unicode MS'; font-size: 10pt; font-weight: normal; font-style: normal; text-decoration: none; color: Black; background-color: Transparent; text-align: left; line-height: 115%">
<div><span style="font-family: 'Courier New'"><img src="data:image/png;base64,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" width="79px" height="48px" alt="sqrt({a^2}/56)+x^3" data-style="font-family: 'Courier New'; font-size: 10pt; color: Black; background-color: Transparent"></span></div></span>]]></writer>
</region>
Example-2
Code:
<div><span style="font-family: 'Courier New'"><img alt="sqrt({a^2}/56)+x^3" data-style="font-family: 'Courier New'; font-size: 10pt; color: Black; background-color: Transparent"></span></div></span>]]></writer>
  </region>
#12 Posted : 16 March 2015 16:54:50(UTC)
The src attribute contains a base64-encoded data URI, it is used to share the math objects to the external word processors as a PNG image. It is not essential in the worksheet code, but I need it for debug/testing purposes, at least for now.
Edited by user 27 January 2017 15:35:54(UTC)  | Reason: test
#13 Posted : 01 April 2015 00:20:02(UTC)
If a writer region with custom wrap setting is cloned using ctrl-drag, then the custom region width gets lost. The wrap setting is still custom but the width extends as if None was specified.
on 01/04/2015(UTC)
#14 Posted : 01 April 2015 02:14:01(UTC)
Thank you, will be fixed in the next relase.
P.S.
I've asked Andrey to extend the APIs to be able to implement this feature Happy
Edited by user 01 April 2015 11:31:54(UTC)  | Reason: Not specified
#15 Posted : 08 April 2015 01:24:28(UTC)
PLUGIN UPDATED SMath Studio 0.97.5575 (07 April 2015)
- Plugin updated to respect changes in SS Core;
- Fixed missing WrapWidth on CTRL+DRAG;
- Toolstrips organization changed to have paragraph's properties grouped;
- Minor changes;
Edited by user 08 April 2015 01:30:49(UTC)  | Reason: Not specified
on 08/04/2015(UTC)
#16 Posted : 02 August 2015 20:14:59(UTC)
PLUGIN UPDATED SMath Studio 0.97.5581 (08 April 2015)
  • Toolbar new features:
    • Toolbar now is available as floating item (can be opened at once in the worksheet);
    • added "Symbol" menu;
      • windows "character map" available from here;
    • added "Change Case" menu;
      • added functions "sentence case", "capitalize each words", "toggle case";
    • "More" menu: New "Options..." item (introduced to set up global options);
      • you can choose between 2 different ways to export data to clipboard; this should enable the region to export math images to any external Word processor*;
      • you can choose the default wrap for the new regions;
      • you can choose to move the new regions on the leftmost page margin, regardless the insertion point;
      • [DEV] LOG utilities available from inside SMath (CTRL+SHIFT+D in this form)
    • fixed critical bugs about non valid values in the font-size DropDown menu;
    • icons reworked;
  • Math objects: the single object now can be copy-pasted as editable math in MS Word** ("paste special" still contains also the plain text and the bitmap image);
  • Changed handling of mouse cursor to avoid annoying flickering;
    • on text selection (noticed with some video drivers);
    • over links on CTRL key pressed (workaround for SS-1239);
  • Hotkeys: CTRL+SHIFT+F assigned to "Copy Format";
  • Fixed critical bug of math objects containing XML special characters;
  • Fixed non selectable hyperlinks written after adding math objects;
  • [DEV] code changes to enable batch TextRegion conversion from next TextRegionUtilities plugin;
  • minor changes & fixes;
PLEASE NOTE:
* Most of the Word processors are able to manage both the modes, however MS Word doesn't handle embedded images, Google Docs and MS Office Online doesn't handle (local) temporary files.
** Some MathML attributes such as colors and alignments are ignored (tests on MS Word up to 2010). It is possible to left-align the items (if, line, while, for, sys, cases) from inside MS Word (Column Alignment > Left).
Edited by user 09 September 2015 18:32:41(UTC)  | Reason: MS Office Online updated
on 02/08/2015(UTC),  on 02/08/2015(UTC),  on 03/08/2015(UTC),  on 04/08/2015(UTC)
#17 Posted : 03 August 2015 17:50:56(UTC)
PLUGIN UPDATED
- Fixed broken resize marker;
on 05/08/2015(UTC),  on 05/08/2015(UTC)
Offline Andrey Ivashov
#18 Posted : 05 August 2015 18:12:01(UTC)
Rank: Administration
Great! Thank you Davide!
What you think if together we will try to include Writer Region into SMath Studio in the Cloud? I believe it may be interesting...
Best regards!
on 05/08/2015(UTC)
#19 Posted : 05 August 2015 20:22:08(UTC)
Hello Andrey Good
I think that would be great, we'll talk about it on Skype ASAP Good
#20 Posted : 07 August 2015 01:45:18(UTC)
Sure!
Guest (2)
7 Pages123>»
