Offline jurep
#1 Posted : 18 June 2015 00:14:09(UTC)
jurep
Slovenia
Hi! I want to save my smath file in to MathCAD file.
While i want to open it in MathCAD i get an error
ERROR
Does anybody have an idea how could i solve this problem?
If it helps im attachin also .sm file to see
GLULAM
Edited by moderator 26 April 2016 14:40:56(UTC)  | Reason: marked as issue
Offline Ernesto
#2 Posted : 18 June 2015 01:09:22(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
Worked for me. File attached.
File Attachment(s):
Dimenzioniranje_GLULAM_2012-10-18.xmcd (91kb) downloaded 57 time(s).
Offline jurep
#3 Posted : 18 June 2015 19:58:53(UTC)
jurep
Slovenia
Thank you man! dont understand what the problem on mine side is Sad
#4 Posted : 19 June 2015 00:50:45(UTC)
Was thanked: 1396 time(s) in 910 post(s)
I think I can reproduce your issue. I can't test it on mathcad thus I need a feedback. The 1st attachment should works while the 2nd should be corrupted.
Edited by user 22 June 2015 18:11:47(UTC)  | Reason: updated files
File Attachment(s):
test_first.xmcd (91kb) downloaded 31 time(s).
test_second.xmcd (91kb) downloaded 25 time(s).
Offline Macs
#5 Posted : 15 July 2015 23:01:57(UTC)
Macs
Rank: Member
Chile
Hi, i have the same problem, anyone knows how repair the document?
Offline Macs
#6 Posted : 15 July 2015 23:03:03(UTC)
Macs
Rank: Member
Chile
Yes, the first open with mathcad and the seccond fail... How u repair?
#7 Posted : 16 July 2015 20:57:03(UTC)
Thank you for the feedback!
I've already reported it as SS-2272.
The settings used by the plugin to save the XMCD file are your system settings (comma as decimal separator, when you get the error). Until a new version of the plugin will be available, you have to change your system settings before launching SMath and then you can save the file. Otherwise the file must be opened with a text editor and you have to fix the xml attributes.
Offline Macs
#8 Posted : 20 July 2015 16:06:05(UTC)
Macs
Rank: Member
Chile
Thanks for your help, but i change the system settings and the problem is still on. I hope the new version of the plugin be avaible soon to use the Smath with all computers in the job (i'm trying to convince my boss Aggressive )
See u soon guys, the program is excelent keep in that way!! Clap
PD: The file is attached Search
Edited by user 21 August 2015 15:06:31(UTC)  | Reason: Not specified
#9 Posted : 20 July 2015 16:44:47(UTC)
You can try if this works... maybe there is another error... Grabli
P.S. just to be sure, for "system settings" I mean the OS settings (in Windows 7: Control Panel > Regional and Language Options > Formats > Additional settings)
Edited by user 20 July 2015 17:12:41(UTC)  | Reason: Not specified
File Attachment(s):
Compuerta Desripiadora - Max.xmcd (77kb) downloaded 30 time(s).
Offline Macs
#10 Posted : 20 July 2015 17:35:49(UTC)
Macs
Rank: Member
Chile
"OS settings" Wallbash Wallbash
Thanks!!!! The problem was solved, u rocks!Good
Offline Macs
#11 Posted : 18 August 2015 18:15:07(UTC)
Macs
Rank: Member
Chile
Hi people me again...
I have a new problem when i save as .xmcd
Attached image and document
Like always, thanks!
Clap
File Attachment(s):
Compuerta TĂșnel - LH1 - 2 Hojas.sm (1,659kb) downloaded 32 time(s).
Macs attached the following image(s):
Offline Macs
#12 Posted : 18 August 2015 22:45:55(UTC)
Macs
Rank: Member
Chile
4 downloads and no reply... this is serious jejeje Help smilie
Offline Ernesto
#13 Posted : 18 August 2015 23:25:41(UTC)
Ernesto
Nicaragua
Its an enormous sheet! Have you tried copying it to a new sheet piece by piece and saving to xmcd, until you found what section was causing that error?
thanks 1 user thanked Ernesto for this useful post.
on 19/08/2015(UTC)
Offline Macs
#14 Posted : 19 August 2015 15:58:57(UTC)
Macs
Rank: Member
Chile
Hehehe, I have been very busy in this sheet ... To find the error, I did yesterday the same like you (copy to a new piece by piece sheet and save XMCD), and the problem was edited image, when the delete the problem is resolved.
Now you know, dont edit images if you want to save XMCD.
Have a nice day, and thanks!
#15 Posted : 19 August 2015 18:34:11(UTC)
This is not completely true, seems the problem is just on the state of the images. If you uncheck the "edit" button everything goes fine. Good
Bug added in the BTS: SS-2274
Edited by user 19 August 2015 18:36:38(UTC)  | Reason: Not specified
File Attachment(s):
Compuerta TĂșnel - LH1 - 2 Hojas_fixed.sm (1,646kb) downloaded 33 time(s).
#16 Posted : 26 April 2016 14:42:18(UTC)
Fix committed, should be available in the next relase.
SS-2274 updated.
Edited by user 10 May 2016 12:40:56(UTC)  | Reason: marked as fixed
