Offline TheWizEd
#1 Posted : 13 July 2010 23:16:47(UTC)
TheWizEd
United States
Was thanked: 19 time(s) in 13 post(s)
Typically the functions min and max return the minumum or maximum value of a list of operands. For example
x:=max(1.1,2.2,3.3,-5.5) would return 3.3 and like wise for minimum.
The SMath functions min and max return the minimum or maximum value of a matrix.
To accomplish this in SMath requires a lot of if ... else statements.
Can this be implemented in SMath and make the min and max functions mmin and mmax for matrix operations?
Ed
Offline TheWizEd
#2 Posted : 14 July 2010 17:01:45(UTC)
TheWizEd
United States
Or I realized, the function can check to see if the parameter passed is a matrix or vector, then do what it currently does. If its a list of operands, return the min or max of the list of values.
Ed
Offline Andrey Ivashov
#3 Posted : 14 July 2010 18:37:06(UTC)
Rank: Administration
Was thanked: 2011 time(s) in 679 post(s)
Yes, this is optimal way how it should work. I'll try to find a time to improve min(..) and max(..) functions later.
Regards.
