#1 Posted : 01 May 2016 16:59:06(UTC)
Was thanked: 983 time(s) in 811 post(s)
This demo is constructed by parts. As it looks, only Mathcad 8/11
[other versions: don't know ?] supports the plotting convolviing
argument in the X/Y plot.
Convolution RC Integration.sm (48kb) downloaded 80 time(s).
on 01/05/2016(UTC)
#2 Posted : 01 May 2016 20:48:11(UTC)
Was thanked: 1393 time(s) in 909 post(s)
same using cases() + symbolic optimization Good
(still needs the annoying eval() for the integration) Sad
2016-05-01 19_47_05-SMath Studio Desktop - [Convolution Integration (cases).sm_].png
Convolution Integration (cases).sm (23kb) downloaded 74 time(s).
#3 Posted : 02 May 2016 17:55:26(UTC)
Thanks Davide,
Works well with the uninstalled 5346.
The installed version does not have your "cases" from f(x) menu.
1/1 Mathcad, very elegant and neat.
on 02/05/2016(UTC)
#4 Posted : 02 May 2016 20:00:52(UTC)
Thank you for your examples Jean, hope to see even more in future (even from other users). Good
Probably "Custom Functions" plugin is missing in the new version. Good
on 02/05/2016(UTC)
#5 Posted : 03 May 2016 04:41:11(UTC)
Oh ! Davide,
I have 100's model ... enough to "wear" Smath
Cheers, Jean
Offline Basile
#6 Posted : 03 May 2016 15:14:43(UTC)
Basile
I get: u - not defined
SMath 5953
Basile
#7 Posted : 03 May 2016 16:45:35(UTC)
SMath 5953
Basile
... Davide might help in there !
#8 Posted : 03 May 2016 18:23:47(UTC)
Apparently, there are a couple of hidden changes in the symbolic engine (both to investigate carefully Umnik )
- the first change involves the transit carrier (fixes in red boxes);
- the second change involves the definition of a function using the function itself in the RHS (fixes in purple boxes; 99% s bug, the function is defined in the dynamic assistant but cannot be evaluated - "function is not defined" exception bug reported as SS-2335);
FIX attached, works with both the versions (0.97 & 0.98)
2016-05-03 17_11_06-SMath Studio Desktop - [Convolution%20RC%20Integration.sm].png
ConvolutionRC Integration [0.98.5953].sm (41kb) downloaded 54 time(s).
Edited by user 03 May 2016 21:04:05(UTC)  | Reason: Not specified
Offline Basile
#9 Posted : 07 May 2016 16:34:03(UTC)
Basile
The simplicity of the previous version has become complicated.
but does not work. Any ideas?
Basile
Edited by user 07 May 2016 16:51:32(UTC)  | Reason: Not specified
Offline PompelmoTell
#10 Posted : 07 May 2016 17:09:27(UTC)
PompelmoTell
Was thanked: 110 time(s) in 94 post(s)
same problem to me
Win7 64 bit
SMath 0.98 build 5953
Solved.
Interference with plugin Maxima
Edited by user 19 May 2016 20:15:11(UTC)  | Reason: Not specified
Offline ndtma
#11 Posted : 07 May 2016 18:07:40(UTC)
ndtma
Sri Lanka
Was thanked: 128 time(s) in 82 post(s)
It works for me.
Win 10 64 bit
SS 0.98 build 5953.
#12 Posted : 08 May 2016 05:15:12(UTC)
Apparently, there are a couple of hidden changes in the symbolic engine (both to investigate carefully )
Ndtma, Sergio, Basile: the above explanation concerns your 5953.
It may also suffer the same logical link bug as 5346 ... like this again.
There are two versions of 5346: the installed version and the NON-installed versions.
Both have substantial differences in what the plugin manager links or does not link
wrt the f(x) menu. For instances: the installed version does link to the Matlab functions
mwxxxxx, the UN-installed version DOES NOT link mwxxx Matlab library, but does link Davide plugin for module 'cases'.
The installed 5346 DOES NOT link Davide plugin 'cases', does not link +++ stuff ...
Levenberg-Marquardt just to cite one.
All what I'm talking about is XP Home SP3. Something else to explore with other WIN OS.
Read again and again what I wrote, up until the brain responds. I know what what I'm
talking about, proof:
Works/does not work is not enough for designers. Prove your assertion(s).
Similar Topics
Convolution Integral [Pulse] (Samples)
by Jean Giraud 04/10/2018 05:33:50(UTC)
Convolution Integral [Two Gaussian] (Samples)
by Jean Giraud 04/10/2018 02:16:28(UTC)
