4 Pages123>»
#1 Posted : 29 March 2016 02:11:53(UTC)
Was thanked: 1378 time(s) in 902 post(s)
CoolProp Wrapper
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Functions
Code:
CoolProp_get_fluid_param_string
CoolProp_get_global_param_string
CoolProp_get_param_index
CoolProp_get_parameter_information_string
CoolProp_HAProps
CoolProp_Phase
CoolProp_Props
CoolProp_Props1
CoolProp_saturation_ancillary
CoolProp_set_reference_stateD
CoolProp_set_reference_stateS
This plugin (clone of the official SMath wrapper linked below, adapted to have it available through the Extensions Manager)
CoolProp
Official SMath wrapper (you have to build it by yourself, instructions in his documentation)
NOTE: you should be able to run worksheets made with a plugin using the other and vice-versa.
Edited by moderator 03 September 2021 13:04:06(UTC)  | Reason: Not specified
on 29/03/2016(UTC)
#2 Posted : 29 March 2016 02:15:24(UTC)
Originally Posted by: Davide Carpi Go to Quoted Post
Code uploaded in the SVN repository (CoolPropWrapper), to make it easily available for further changes.
UPDATED
- CoolProp 5.1.2
on 29/03/2016(UTC),  on 11/04/2016(UTC)
Offline mikekaganski
#3 Posted : 11 April 2016 20:12:47(UTC)
mikekaganski
A sheet to see some of CoolProp functions.
CoolProp_demo.sm (118kb) downloaded 367 time(s).
EDIT: Updated the demo (using development version of library).
Edited by user 05 June 2016 23:07:43(UTC)  | Reason: Not specified
Best regards,
Mike Kaganski
thanks 3 users thanked mikekaganski for this useful post.
on 11/04/2016(UTC),  on 12/04/2016(UTC),  on 12/04/2016(UTC)
Offline Razonar
#4 Posted : 06 May 2016 06:59:54(UTC)
Razonar
Uruguay
Was thanked: 921 time(s) in 586 post(s)
Very useful!
Thanks
#5 Posted : 06 May 2016 15:38:56(UTC)
Was thanked: 983 time(s) in 811 post(s)
"Alvaro" was great collab from the former Mathsoft Collaboratory.
At that time of the Mathsoft Collaboratory, I signed "jmG".
Here is a hint: your great Mathcad 11 "Dichotomy" module.
Offline Razonar
#6 Posted : 09 May 2016 10:05:13(UTC)
Razonar
Uruguay
Hi, Jean. Yes, it's "me" (and my personal english too). ¿How are you?
Offline Razonar
#7 Posted : 02 June 2016 13:00:23(UTC)
Razonar
Uruguay
Hi. I don't know how to call the functions CoolProp_set_reference_stateD nor
CoolProp_set_reference_stateS. See the yellow in the attached.
P3.sm (119kb) downloaded 128 time(s).
#8 Posted : 02 June 2016 16:41:17(UTC)
mikekaganski
https://github.com/CoolProp/CoolProp/issues/1091
Regarding CoolProp_set_reference_stateS, AFAICT, it works OK, following the definition given in https://github.com/CoolP...aster/include/CoolProp.h :
Code:
    Set the reference state based on a string representation
    @param FluidName The name of the fluid (Backend can be provided like "REFPROP::Water", or if no backend is provided, "HEOS" is the assumed backend)
    @param reference_state The reference state to use, one of
    Reference State | Description
    "IIR"           | h = 200 kJ/kg, s=1 kJ/kg/K at 0C saturated liquid
    "ASHRAE"        | h = 0, s = 0 @ -40C saturated liquid
    "NBP"           | h = 0, s = 0 @ 1.0 bar saturated liquid
    "DEF"           | Reset to the default reference state for the fluid
    "RESET"         | Remove the offset
    The offset in the ideal gas Helmholtz energy can be obtained from
    {Δs}/{R_u/M}+{Δh}/{(R_u/M)T}τ
    where Δs = s-s_{spec} and Δh = h-h_{spec}
    void set_reference_stateS(const std::string &FluidName, const std::string &reference_state);
with the only exception that "RESET" doesn't remove any offset.
Edited by user 03 June 2016 02:35:30(UTC)  | Reason: Not specified
Best regards,
Mike Kaganski
Offline Razonar
#9 Posted : 02 June 2016 19:55:47(UTC)
Razonar
Uruguay
Originally Posted by: mikekaganski Go to Quoted Post
Regarding CoolProp_set_reference_stateS, AFAICT, it works OK, following the definition given in https://github.com/CoolP...ster/include/CoolProp.h:
In the attached there are a similar information, from github too, but referent to the wrapper. Can provide a smath example changing the refstate and showing h or s values changing? I can't do that inside smath.
Thanks in advance
Edited by moderator 02 June 2016 21:40:06(UTC)  | Reason: fixed quote BBcode
Offline Razonar
#10 Posted : 02 June 2016 22:11:35(UTC)
Razonar
Uruguay
#11 Posted : 03 June 2016 00:03:44(UTC)
mikekaganski
refstate.sm (49kb) downloaded 127 time(s).
WRT CoolProp_set_reference_stateD, I do agree it doesn't work for now, which is why I filed a bug upstream.
Best regards,
Mike Kaganski
#12 Posted : 05 June 2016 23:28:43(UTC)
mikekaganski
@Davide,
Is it worth it to turn the plugin to newer interface, I mean Entry instead of Term[]? Which oldest SMath will be supported then?
Best regards,
Mike Kaganski
#13 Posted : 06 June 2016 01:03:36(UTC)
@Davide,
Maybe yes, however soon or later should be done. Entry class is since 0.98, therefore supported versions as for now they would be only 0.98.5935 Stable and further nightly builds.
BTW in NonlinearSolvers refactoring I've switched all the functions to that interface (with different degrees of changes; some are just linked to Entry in the input/output points, in some other cases I've take advantage of the Entry features to make deep changes)
#14 Posted : 06 June 2016 18:22:10(UTC)
mikekaganski
@Davide,
is there a documentation available (aside the source code itself)?
Thank you for your help.
Best regards,
Mike Kaganski
#15 Posted : 06 June 2016 18:49:55(UTC)
I've asked Andrey to publish the updated core documentation, I guess we have to wait the next Stable build...
If you want to try by examples: https://smath.info/svn/public/plugins/NonlinearSolvers/NIGHTLY BUILD/; in Tools you may found the most simpler examples (Taylor is an easy example of conversion in the input/output nodes using Terms; Unknowns makes use of Entry to do the job, Terms are used to build the output)
#16 Posted : 08 June 2016 16:05:09(UTC)
mikekaganski
Making it run on mono under Ubuntu:
Hope it will be available in next version of plugin.
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 08/06/2016(UTC)
#17 Posted : 25 October 2016 20:17:52(UTC)
Beta UPDATED Stable: SMath Studio 0.98.6128
- CoolProp 6.1.0;
- refactored to new SS fast interface (please test it a little so I can see if make it stable or I have to fix/change something);
on 25/10/2016(UTC)
#18 Posted : 25 October 2016 23:05:43(UTC)
mikekaganski
Thanks, Davide!
Here's what I see:
Also, no dynamic assistance is available. Though disabling the plugin doesn't help.
Best regards,
Mike Kaganski
#19 Posted : 26 October 2016 04:21:34(UTC)
Though I don't use Smath unit system, two questions come to evidence:
1. 'Q' does not not belong to WASP [WaterSteamProperties].
2. '1' is what ? ... maybe '1' is atm in the 2nd line ?
If "Units don't match": how could the dynamic assistance help ?
The coulomb (unit symbol: C) is the International System of Units (SI) unit of electric charge.
It is the charge (symbol: Q or q) transported by a constant current of one ampere in one second:
1 C = 1 A * 1 s
1 ((Pa * m * s^2) / kg) * bar = 100 000 pascals
#20 Posted : 26 October 2016 10:27:20(UTC)
Hello Mike,
Reproduced, thank you. I'll fix it ASAP Good
This is really strange, I have the dynamic assistant both in install and portable versions and using different localizations (languages/symbols) Wonder
Hello Jean, according with CoolProp documentation "Q" stands for "Mass vapor quality", thus 1 is 1 mol/mol
I guess it is a separate bug Good
Edited by user 26 October 2016 10:29:26(UTC)  | Reason: Not specified
4 Pages123>»
