Offline CBG
#1 Posted : 31 August 2016 18:58:56(UTC)
CBG
If you protect a region with a password, and this region is closed , to save the "sm " executable ( " .exe" ) Smath Viewer Pro file is not recognized as a Windows executable .
and if you save it as " exe " file Smath Viewer free , the file is saved correctly and is recognized by windows , but there is no way that within the executable , you can open the protected region.
Edited by moderator 10 September 2016 20:34:59(UTC)  | Reason: Not specified
#2 Posted : 31 August 2016 20:47:51(UTC)
Was thanked: 1396 time(s) in 910 post(s)
I cannot reproduce the issue. Could you attach a simple example?
Edited by user 01 September 2016 11:45:36(UTC)  | Reason: Not specified
Offline CBG
#3 Posted : 01 September 2016 04:03:59(UTC)
CBG
With a simple example, Smath Viewer, stopped working . Annex example
Test_Region_Protect.7z (927kb) downloaded 51 time(s).
#4 Posted : 01 September 2016 11:44:32(UTC)
Thank you! I see the problem is related in some way with the separator as first region (title modified). There is a conflict between the separator title and the collapsed encrypted area.
Bug added in the BTS (SV-2373), I'll investigate code-side ASAP.
Edited by user 01 September 2016 12:29:54(UTC)  | Reason: Not specified
Offline CBG
#5 Posted : 02 September 2016 17:49:34(UTC)
CBG
Hello Davide:
The 0.98 build 6089 Smath Studio new version solves the problem for Smath Viewer Free , but not for the PRO version.
One question: Is it possible that you can open a protected region inside of Smath Viewer ?
Thank you.
#6 Posted : 02 September 2016 18:42:38(UTC)
Hello Carlos,
confirmed, thank you Good
If the encrypted region is not collapsed, everything should works as expected; if it is collapsed, you can't see values generated from inside this area (currently listed as bug SV-2374)
Edited by user 31 October 2016 17:29:54(UTC)  | Reason: marked ad solved
