Offline Andrey Ivashov
#1 Posted : 05 October 2016 22:03:48(UTC)
Rank: Administration
Was thanked: 1983 time(s) in 668 post(s)
Release Candidate: SMath Studio 0.98.6122 available
Latest changes (against SMath Studio 0.98.6103)
  • [SS-2409]: Return value for indeterminate argument by UnitsOf() function fixed;
  • [SS-2318]: Preprocessing of symbolic data / functions' arguments finally fixed;
  • [SS-111], [SS-2327]: Fixed issues with functions arguments names interference;
  • [SV-2377]: Viewer: Issue when protected Area Regions was shown as tabs fixed;
  • [SS-2411]: Symbolic simplification of functions arguments fixed;
  • Detection of 0^0 error disabled for operations performed by numerical methods (like Integration or Gamma function);
  • Function range(3) improved to fix issues with lost last value of result vector;
  • Glitches happened sometimes on insert new Regions after collapsed Area Regions fixed;
  • About dialog extended to show if application is started in 32/64-bit mode;
  • Silent mode extended with -b argument (summary mode of output);
  • Consistency fix for el(...) function - when matrix used as indices (elements by row then by column);
  • Support for matrix as index feature added for sys(..) + several input errors handled;
  • Refactoring.
UPDATE: Changes against SMath Studio 0.98.6122
  • Support for units in range(2) implemented (base unit of the range start value used for increment);
  • Automatic scrolling to the Region just added to the Worksheet improved;
  • Incorrect location of Separator Region inserted by Ctrl+Enter press fixed (now it is added exactly on the place where cursor is located);
  • Visual glitches fixed when using Ctrl+Click functionality to select Regions on the Worksheet;
  • Special Region placeholder is now shown instead of incorrectly loaded Regions on file open;
  • Refactoring and code simplifications;
  • [Against to 0.98.6122 only]: Support for units in range(3) restored;
  • [Against to 0.98.6122 only]: Hotkeys for Math Regions restored.
Download
Edited by user 06 October 2016 17:07:17(UTC)  | Reason: Not specified
thanks 8 users thanked Andrey Ivashov for this useful post.
on 05/10/2016(UTC),  on 05/10/2016(UTC),  on 06/10/2016(UTC),  on 06/10/2016(UTC),  on 06/10/2016(UTC),  on 06/10/2016(UTC),  on 06/10/2016(UTC),  on 06/10/2016(UTC)
Offline mikekaganski
#2 Posted : 06 October 2016 01:17:22(UTC)
mikekaganski
I seem to be unable to use "[" shortcut to el() function.
Edit: The same for root ("\" )
Edited by user 06 October 2016 01:45:29(UTC)  | Reason: Not specified
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 06/10/2016(UTC)
#3 Posted : 06 October 2016 01:54:07(UTC)
mikekaganski
Units are lost in range(2):
Best regards,
Mike Kaganski
on 06/10/2016(UTC)
Offline omorr
#4 Posted : 06 October 2016 12:40:17(UTC)
omorr
Serbia
Confirmed
Offline omorr
#5 Posted : 06 October 2016 12:42:00(UTC)
omorr
Serbia
Confirmed
#6 Posted : 06 October 2016 16:18:03(UTC)
mikekaganski
Problems with "[", "]", "\" and units in range are fixed in appVersion(4)="0.98.6123.7493"
Best regards,
Mike Kaganski
on 06/10/2016(UTC)
#7 Posted : 06 October 2016 17:09:45(UTC)
Thank you Mike!
Yes, issues you have found are fixed (not only thoose ones) and new build created.
Please see updated first comment for list of changes.
Best regards, Andrey Ivashov.
on 06/10/2016(UTC),  on 07/10/2016(UTC)
Offline GreatGehar
#8 Posted : 07 October 2016 18:46:07(UTC)
GreatGehar
Hello.
In Windows version I insert image on the document page and save it. After I open this document on the Linux and don't see image. But on Windows image be show.
(Sorry for bad English)
Offline Alex M.
#9 Posted : 07 October 2016 19:15:43(UTC)
Alex M.
Originally Posted by: GreatGehar Go to Quoted Post
Hello.
If it is related to the "Image Region" please post in the corresponding thread of the plugin - I will attempt to help you.
