SMath Studio Forum
Samples
Numerical parameterization implicit surfaces of the form f (x, y, z) = 0
The grid lines are found by Draghilev Method Method 1. Building a line of intersection of the required surface with the plane x = 0. This line is rotated in steps of 2 * Pi / s about a vertical axis by an angle 2 * Pi, where s is the number of steps (the grid lines) Edited by user 21 October 2018 20:26:30(UTC)
1 user thanked Ber7 for this useful post.
3 users thanked Ber7 for this useful post.
on 18/12/2016(UTC), on 19/12/2016(UTC), on 19/12/2016(UTC)
Two surfaces are taken from the site http://xrt.wikidot.com/gallery:implicitThe calculation algorithm: 1.Find the line of intersection of the given surface with the plane Z=0 2.Through each point hold the plane x1 = C and find the line of intersection of that plane with a given surface.These lines represent a given surface. double torus x2.sm (74kb) downloaded 44 time(s). Bretzel (4 holes).sm (215kb) downloaded 35 time(s).Edited by user 30 January 2017 09:27:33(UTC)
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Thanks for these two animations. In each one, the last three plots stay red, though the animated plot works fine. A small detail: each work sheet has three definitions left over at page 17.
Thank you Jean, Worksheets corrected. In addition, in the algorithm for calculating along with x1 = C can be used x2 = C: double torus x2.sm (74kb) downloaded 40 time(s).
2 users thanked Ber7 for this useful post.
on 30/01/2017(UTC), on 30/01/2017(UTC)
Thanks Ber7 for the work sheets [Not finished downloading]. If you visit this document, I'm wondering: " How to add red points in this plot". Thanks in advance ... Jean Maths sph2xyz.sm (14kb) downloaded 34 time(s).
Hello Jean, Unfortunately, the 3d chart does not allow you to draw points. Exit (hopefully temporary) -make a 3d chart on a 2d chart. Maths sph2xyz2d.sm (22kb) downloaded 41 time(s).
on 06/02/2018(UTC), on 06/02/2018(UTC), on 06/02/2018(UTC)
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Nice examples! Just some remarks for those who want to play around with Maxima Draw. - Instead of Image region with Draw() command you can use Maxima Draw3D region with interactive zoom, rotation and resize and a settings dialog.
Insert-> Maxima-> Draw3D
- The performance isn't overwhelming, as the image is recalculated for each interaction.
- The snippet "draw" provides help texts for the available draw commands and options.
- Follow the link in my signature to see how to configure SMath with Maxima.
ImplicitMaxima_Kr.sm (493kb) downloaded 37 time(s).Edited by user 06 February 2018 11:09:11(UTC)
4 users thanked mkraska for this useful post.
on 06/02/2018(UTC), on 06/02/2018(UTC), on 06/02/2018(UTC), on 06/02/2018(UTC)
SMath Studio Forum
Samples
