Offline Ber7
#1 Posted : 30 May 2015 02:25:23(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
The grid lines are found by Draghilev Method
Method 1.
Building a line of intersection of the required surface
with the plane x = 0. This line is rotated in steps of 2 * Pi / s
about a vertical axis by an angle 2 * Pi, where s is the number of steps (the grid lines)
Edited by user 21 October 2018 20:26:30(UTC)  | Reason: Not specified
thanks 1 user thanked Ber7 for this useful post.
on 31/05/2015(UTC)
Offline Ber7
#2 Posted : 30 May 2015 02:39:51(UTC)
Ber7
Israel
Method 2.
The rectangular grid
Edited by user 30 May 2015 02:42:49(UTC)  | Reason: Not specified
File Attachment(s):
Algorithm.smz (10kb) downloaded 85 time(s).
Implicet.smz (14kb) downloaded 92 time(s).
ELLIPSE3d2.pdf (632kb) downloaded 88 time(s).
on 31/05/2015(UTC)
Offline Ber7
#3 Posted : 18 December 2016 00:17:47(UTC)
Ber7
Israel
The graph an implicit surface depicted by lines
Examples of the idea of ​​the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/ques...Of-Surfaces#answer233804
Bublik.sm (35kb) downloaded 50 time(s). Cushion.sm (39kb) downloaded 39 time(s). DupinCyclide.sm (37kb) downloaded 39 time(s). Sur2.sm (39kb) downloaded 39 time(s). Surface4.sm (36kb) downloaded 43 time(s).
Edited by user 18 December 2016 00:22:36(UTC)  | Reason: Not specified
thanks 3 users thanked Ber7 for this useful post.
on 18/12/2016(UTC),  on 19/12/2016(UTC),  on 19/12/2016(UTC)
Offline Ber7
#4 Posted : 29 January 2017 22:56:41(UTC)
Ber7
Israel
Two surfaces are taken from the site
http://xrt.wikidot.com/gallery:implicit
The calculation algorithm:
1.Find the line of intersection of the given surface with the plane Z=0
2.Through each point hold the plane x1 = C and find the line of intersection of that plane with a given surface.These lines represent a given surface.
double torus x2.sm (74kb) downloaded 44 time(s). Bretzel (4 holes).sm (215kb) downloaded 35 time(s).
Edited by user 30 January 2017 09:27:33(UTC)  | Reason: Not specified
on 30/01/2017(UTC)
#5 Posted : 30 January 2017 05:28:16(UTC)
Thanks for these two animations. In each one, the last three plots
stay red, though the animated plot works fine. A small detail:
each work sheet has three definitions left over at page 17.
on 30/01/2017(UTC)
Offline Ber7
#6 Posted : 30 January 2017 09:51:39(UTC)
Ber7
Israel
Thank you Jean,
Worksheets corrected. In addition, in the algorithm for calculating along with x1 = C can be used x2 = C:
double torus x2.sm (74kb) downloaded 40 time(s).
thanks 2 users thanked Ber7 for this useful post.
on 30/01/2017(UTC),  on 30/01/2017(UTC)
Offline Ber7
#7 Posted : 31 January 2017 23:50:55(UTC)
Ber7
Israel
The tube in the form of a line of intersection of the cylinder and the torus (See post 7)
http://en.smath.info/for...-spatial-mechanisms.aspx
Time calculation, 9 min.
Villarceau 9.sm (40kb) downloaded 41 time(s).
on 01/02/2017(UTC)
Offline Ber7
#8 Posted : 01 March 2017 10:25:37(UTC)
Ber7
Israel
Helical Tube
NonCirc.sm (54kb) downloaded 37 time(s).
TubeCir.sm (54kb) downloaded 38 time(s).
Edited by user 01 March 2017 17:00:55(UTC)  | Reason: Not specified
on 01/03/2017(UTC)
Offline Ber7
#9 Posted : 01 March 2017 10:44:07(UTC)
Ber7
Israel
The surface of the Wikipedia
https://en.wikipedia.org/wiki/File:Tri-brezel.svg
WiciSurf.sm (107kb) downloaded 38 time(s).
on 01/03/2017(UTC)
Offline Ber7
#10 Posted : 14 June 2017 19:27:49(UTC)
Ber7
Israel
Non-circular cylindrical vessels with quasi-ellipsoidal ends
Krivoshapko S.N. Ivanov V.N,Encyclopedia of Analytical Surfaces ,Springer,2015
Non-circular cylindrical vessels.pdf (1,297kb) downloaded 38 time(s).
Non-circular cylindrical vessels.sm (210kb) downloaded 34 time(s).
Shell1.sm (256kb) downloaded 36 time(s).
Shell2.sm (34kb) downloaded 29 time(s).
Shell3.sm (35kb) downloaded 33 time(s).
Edited by user 14 June 2017 19:39:56(UTC)  | Reason: Not specified
#11 Posted : 15 June 2017 15:43:57(UTC)
Thanks Ber7 for the work sheets [Not finished downloading].
If you visit this document, I'm wondering:
"How to add red points in this plot".
Thanks in advance ... Jean
Maths sph2xyz.sm (14kb) downloaded 34 time(s).
Offline Ber7
#12 Posted : 15 June 2017 18:23:51(UTC)
Ber7
Israel
Hello Jean,
Unfortunately, the 3d chart does not allow you to draw points.
Exit (hopefully temporary) -make a 3d chart on a 2d chart.
Maths sph2xyz2d.sm (22kb) downloaded 41 time(s).
Offline Ber7
#13 Posted : 06 February 2018 09:56:52(UTC)
Ber7
Israel
Implicit surfaces in Maxima
ImplicitMaxima.sm (364kb) downloaded 45 time(s).
Edited by user 26 April 2022 18:01:45(UTC)  | Reason: Not specified
on 06/02/2018(UTC),  on 06/02/2018(UTC),  on 06/02/2018(UTC)
#14 Posted : 06 February 2018 11:06:49(UTC)
Nice examples!
Just some remarks for those who want to play around with Maxima Draw.
  • Instead of Image region with Draw() command you can use Maxima Draw3D region with interactive zoom, rotation and resize and a settings dialog.
    Insert-> Maxima-> Draw3D
  • The performance isn't overwhelming, as the image is recalculated for each interaction.
  • The snippet "draw" provides help texts for the available draw commands and options.
  • Follow the link in my signature to see how to configure SMath with Maxima.
ImplicitMaxima_Kr.sm (493kb) downloaded 37 time(s).
Edited by user 06 February 2018 11:09:11(UTC)  | Reason: Not specified
thanks 4 users thanked mkraska for this useful post.
on 06/02/2018(UTC),  on 06/02/2018(UTC),  on 06/02/2018(UTC),  on 06/02/2018(UTC)
Offline Ber7
#15 Posted : 21 February 2018 22:41:18(UTC)
Ber7
Israel
Continuation:
MaximPlus1.sm (238kb) downloaded 36 time(s).
Edited by user 26 April 2022 18:11:23(UTC)  | Reason: Not specified
on 22/02/2018(UTC)
