Joined: 15/05/2016(UTC) Posts: 22 Location: Daejeon Was thanked: 1 time(s) in 1 post(s)
Hi I need a help for "FindRoot" function.(See attached file) Also I got an error sample file(Inst_Colebrook_pipe_data.sm) which was downloaded from this forum. Please, guide me to solve this error. Novice FindRoot_test_0.sm (41kb) downloaded 21 time(s). Inst_Colebrook Pipe Data.sm (61kb) downloaded 17 time(s).Edited by user 10 July 2017 22:03:29(UTC)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,639 Location: Italy Was thanked: 1323 time(s) in 873 post(s)
Hello
Novice
An important thing is that Q1 must be undefined while you define the system of equations - and as for now even when you call FindRoot; there is a buil-in function Clear(...) for this. Secondly as for now when there are numerical functions involved in the evaluation of the unknowns this plugin has issues (in this case the issue is in if(f(Q1), that can be replaced by cases(...), however the algorithm then fails to solve for the given initial guess); FindRoot_test_0.sm (39kb) downloaded 28 time(s).I'm working to improve both these things. Edited by user 12 July 2017 01:43:22(UTC)
Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Dear Jean,
Thank you very much for your advice and examples It is helpful to me.
Thank you!
MS
