Hello! I have a dual boot machine running Ubuntu 16.04 and Windows 10, and my files are on a thumb drive. When working in Windows the plugin accesses the ods file without any problem: When working in Ubuntu however, I get "Path is empty". When I rename the file by removing "s" from materials I get "The File /path/material.ods does not exist". So It appears to be finding the file, but not able to read it: The ods file was originally saved in LibreOffice Calc. I downloaded GNUmeric and saved the ods file in "strict" and "extended" file formats to be sure the problem wasn't with LibreOffice. I have the same problem with all versions of the ods file. I have tried using the full path name on the thumb drive and from the home folder, same problem on both. When I installed SMath last week I installed mono from the Ubuntu repositories, so it should be the last stable release. Any suggestions would be of great help! Thanks Dave ms file: MAST.sm (3,578kb) downloaded 14 time(s).Edited by user 08 October 2017 21:37:48(UTC)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,639 Location: Italy Was thanked: 1323 time(s) in 873 post(s)
Hello Dave,
I'll look into it as soon as possible.
It might be an issue with the zip library, but I'm not sure. |
Just found the issue; as I was thinking, it's a problem in the zip library ( #17745). I'll provide a fix ASAP. Edited by user 13 October 2017 13:42:45(UTC)
| Reason: marked as SOLVED |
