Then writing master thesis I need numbering equation there's a methods to put number on equation, or simple I need put the text near formulas. Example: 3+4=8 (101) 2+3=5 (102) Edited by user 05 November 2017 06:03:53(UTC)
Hello
Paulius
, You can start writing a text region simply by typing the double quotes character ( ") anywhere in the canvas You can even use the description area (right click on the math region -> show description) and move it to the side you want dragging his left edge. |
Equation [1], [2] are one line, they lineup nicely. For equation of num/den style: use a construction line that you will delete after construction.
You can highlight a graph or any math region simply: 1. capture the graph frame using "WinGrab" [freeware] 2. crop the Wingrab selected region 3. copy/paste in IrfanView, inverse colors Inst_Mach Number Pitot [PUBLISH].sm (31kb) downloaded 19 time(s).
