Joined: 11/01/2018(UTC) Posts: 131 Location: Wisconsin Was thanked: 58 time(s) in 37 post(s)
I'm curious if there is a location where you can view the extent what a given Plugin 'does'. Short of Enabling a Given Plugin and viewing those new functions and checking new options, I am not aware of a resource that Outlines all that a Plugin is capable of.
I know this is a loaded question, but any guidance is appreciated.
Conceptual Example of what I am looking for (note, this 'plugin' in the example does not exist): Name of Plugin: TrigPackage Author: Some Guy Version: xxx Description: Contains Trig Functions
FUNCTIONS: 1: sin(x) - DESC: Trig Function; Sin; Opposite over Hyp. - (IN) x as angle (unit = degree/radians) - (OUT) double - unitless 2: tan(x) - DESC: Trig Function; Opposite over Adjacent - (IN) x as angle (unit = degree/radians) - (OUT) double - unitless; throws error if 90deg
TOOLBARS: 1: [INSERT] MENU -> [INSERT GRAPH WITH SIN CURVE]
Any ideas?
Thank You, Kenny |
Joined: 15/04/2012(UTC) Posts: 1,980 Was thanked: 1120 time(s) in 718 post(s)
Typically, the most reliable source of information is the forum (subforum extensions). Usually, the author of a plugin also opens a topic there. Also, some of the authors might maintain the extension page on the SMath website just like this. Some information on plugins is also found in the interactive handbook. |
