Can't explain to myself double/triple nesting [6179 Win 7]. Bugs SlopeIntercept.sm (11kb) downloaded 30 time(s).
Hello Jean, something to check in the symbolic engine; change the optimization of a:Intercept(vx,vy) from symbolic to numeric Edited by user 15 January 2018 16:08:56(UTC)
| Reason: maarked as SOLVED |
Thanks Davide ... works fine Numeric !
Fixed. Will be available with a next nightly build.
Thank you!
Originally Posted by: Andrey Ivashov Fixed. Will be available with a next nightly build.
Was just a matter of RIGHTdoing. Thanks Andrey to keep me addict to Smath !
I get these errors when I run the file: Best Regards Carlos
Originally Posted by: CBG I get these errors when I run the file: Carlos, try this one [done Smath 6179] Maths SlopeIntercept.sm (10kb) downloaded 27 time(s).
Thanks Jean, but I get the same error.
Is your Smath studio 32-bit?
My Smath Studio 64-bit, does not recognize the functions of Interception and slope.
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hello! Jean's example also works in my laptop (Win 10, 64 bit) with latest SS 6588 dated 14/01/2018. The Functions are in Statistical Tools Plugin. Edited by user 16 January 2018 09:47:58(UTC)
Originally Posted by: CBG My Smath Studio 64-bit, does not recognize the functions of Interception and slope. Originally Posted by: ndtma The Functions are in Statistical Tools Plugin. Carlos, do you have statistical tools plug-in installed and enabled? |
Quote:Carlos, do you have statistical tools plug-in installed and enabled? Yes I have it. Best regards Carlos
I see, trying to figure out what's happening here |
