Hello to all here, First an observation: (see attached screenshot) 1) The file explorer shows the wrong time ,Last Access'. It differs from the sequence, with which I worked at the files (I did a safe as, and saved the file without _[0-9][0-9] last, overwriting an earlier version) At Krusader or Dolphin, the date is shown correctly. 2) Is there a way to change the format of the date to 24h-format and dd-mm-yyyy ? Greetings, H.Steffen
