Joined: 04/07/2015(UTC) Posts: 6,868 Was thanked: 980 time(s) in 808 post(s)
Hello Jean. The scale of the mesh next to the x and y axes is not correct, since it is half the unit on each side. Best Regards Carlos
Originally Posted by: CBG Hello Jean.
The scale of the mesh next to the x and y axes is not correct, since it is half the unit on each side. Easy to fix, Carlos ... like this. It's normal the [XY axes] don't split exactly ½ way in between the grid. Grid is 9 pixels, the native QuickPlot grid spacing is 41 pixels. Handles will give either 40/41 but not 40.5. However, far superior to Mathcad/Mathsoft. 2D Plot Discrete over Grid.sm (17kb) downloaded 20 time(s).
